Pro Capture with back button focus
Started Dec 16, 2019 | Discussions
Merlinator
Merlinator Regular Member • Posts: 233
I've been out working with, for me, a whole new system the olympus om-d e-m1 mark ii.  I've had some success with BIF, I'll post picks later, but when I tried pro capture it didn't work.  Do I have to turn off back button focus when I use pro capture or is there a way to use it with BBF?
Thanks very much to all that have responded to my previous questions about this camera.
Thanks, Roy
www.merlnator.smugmug.com
 Merlinator's gear list:Merlinator's gear list
Sony a1
Olympus E-M1
Denjw
Denjw Veteran Member • Posts: 6,781
Re: Pro Capture with back button focus
In Pro Capture you can only use BBF to focus not to activate shutter. So  when using BBF with Pro Capture you still have to half press the shutter button to activate pre frame shutter and fully press it to activate recording  frames.
 Denjw's gear list:Denjw's gear list
Olympus E-300 Olympus E-30 Olympus E-5 Olympus E-M1 Olympus E-M1 II +17 more
Jouko Senior Member • Posts: 1,846
... And the "slower ProCapture" with CAF works just with m.Zuiko lenses. The faster one works with about all lenses, but uses S-af (or manual focus) for the first frame. So, there are limitations, but you'll get a lot of frames shot...
Cheers!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
Messier Object Forum Pro • Posts: 10,843
In fact it works only with OLYMPUS m.Zuiko lenses
Cheers!
the compatibility chart can be found here:
https://asia.olympus-imaging.com/product/dslr/em1mk2/feature.html
Peter
Merlinator
OP Merlinator Regular Member • Posts: 233
Ah, that is what I was doing wrong.
Thanks, Roy
Sony a1
Merlinator
Cheers!
Jouko
Jouko, the only lenses I plan to use will be pro lenses.
Thanks, Roy
Sony a1
Merlinator
Cheers!
Peter
Peter, thanks for posting the link.  That page has some interesting information on it.
Thanks, Roy
Sony a1
