Disadvantages of K1ii with APSC lenses?
Started Dec 16, 2019 | Questions
Phil_Rose
Phil_Rose Senior Member • Posts: 1,044
Hi all, title pretty much self explanatory! I have a K3 and a K3ii with 9 lenses, most of them APSc. If i bought a K1ii and then waited to recover from the cost before slowly going FF on the lenses, is there any disadvantage using the K1ii with APSc lenses compared with using the K3ii or K3 cameras designed for APSc?
Thanks for your thoughts!
Phil
I like turtles.
www.philrosephoto.com
PeterPentax
PeterPentax Senior Member • Posts: 1,131
Re: Disadvantages of K1ii with APSC lenses?
What lenses do you have at the moment ? Many aps-c lenses are totally compatible with FF, some are almost compatible (minor vignetting).
Your K3 has a higher pixel pitch than the K1..... 24MP squeezed into the aps-c sensor compared to 36MP into the FF sensor.
If you depend on wildlife and crop extensively, I would say stick with K3. If not then go for the advantages k1 and K1II has
MightyMike Forum Pro • Posts: 41,691
Phil
First off there would be little to no disadvantages other than not using the full sensor and getting less resolution...
However how about you list the lenses you have and we tell you if any of them can actually be used as a FF lens despite its designation
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Phil_Rose
OP Phil_Rose Senior Member • Posts: 1,044
Sure! Let's see if I can remember them while here at the office!
Pentax 10-16mm f3-4.5
Sigma 18-50 f2.8
Pentax 50mm 2.8
Pentax 35mm f2.4 (if I remember correctly)
Samyang 85mm 1.4 (FF, I believe)
Pentax 100mm Macro (FF, I think)
Pentax 60-250mm f4
Pentax 50-135 2.8
Oh, Rokinon 14mm as well.
I think that's all of them! Some of the specs may not be perfect but you get the gist!
Thanks for all the help so far. I appreciate it.
Phil
I like turtles.
Polacofede Senior Member • Posts: 1,409
Sigma 18-50 f2.8
Pentax 50mm 2.8
Pentax 60-250mm f4
you should de baffle it, with care, is pretty simple. I did it. ( dont use a dremel ! )
Pentax 50-135 2.8
I think that is FF too
Phil
 Polacofede's gear list:Polacofede's gear list
Panasonic Lumix DMC-FZ200 Olympus XZ-2 iHS Pentax K-50 Pentax K-3 II Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +6 more
Phil_Rose
De baffel it? I am baffled. Can you de baffle me?! Does that mean it can be a FF lens?
I like turtles.
This is the 10-17mm F3.5-4.5 and it should cover the FF image circle near the 17 end
Sigma 18-50 f2.8
Most likely APS-C only
Pentax 50mm 2.8
This is a FF lens if its the macro, if its the 50mm F1.8 then yes it too covers FF
This lens cover FF
Yes its FF
Yes its FF
Pentax 60-250mm f4
There are instructions for doing this on pentaxforums
Pentax 50-135 2.8
Definitely APS-C only
Phil
Mike from Canada
https://www.dpreview.com/forums/thread/4031365
Mike from Canada
Phil_Rose
Wow! I have a lot of FF options it seems!
The 50mm is the macro! That's great.
I found https://www.pentaxforums.com/articles/photo-articles/how-to-modify-da-star-60-250mm-f4-full-frame.html in case anyone else is looking.
Phil
I like turtles.
Phil_Rose
This de baffling looks scary. Is it OK to just remove the baffle or do I need to modify it? I guess I would need to modify at least or, ideally replace it?
Thanks!
Phil
I like turtles.
Thanks!
Phil
You can remove it completely, however there was a review that suggested a replacement performed better, I believe you can buy the replacement from someone who has 3D printed it but since I don't own one I never bothered to look them up. don't go beyond what you're comfortable with, and if you're comfortable cropping out the worst of the vignetting then don't worry about it.
Mike from Canada
Thanks!
Phil
as far as i remember i havent read anyone complaining of quality issues after de baffing it. I did it and improved a lot for astro as there is much less vignetting. So i would say you can just remove the baffle, i wouldn't modify it. When removing it, and assembling it back take care to not bend the contacts as otherwise AF will not work ( in case it happens you will need to open it again and place them properly.
Phil_Rose
Yeah. I think I'd just create an 'action' in Exposure to crop, at least until I got my nerve up! Could be a very VERY niche service someone could offer!
I like turtles.
but is extremely simple. It took me around 5 minutes. Just try to take the time specific for that as if you are doing other things in the same time you risk loosing screws or some other issues.
Phil_Rose
OK. I might give it a go assuming I ever buy a K1. I think I'm going to wait for the new APSC flagship to come out and see what the specs are like on that. Maybe. Or maybe a use K1 or K1ii would be a better move. I don't know. I've been happy with APSc all these years. Would I just be blown away by a FF? Not sure!
Phil
I like turtles.
Terry K1
Terry K1 Senior Member • Posts: 1,616
What do you photograph?
 Terry K1's gear list:Terry K1's gear list
Sony FE 50mm F1.2 GM Sony a7R IV Sony FE 90mm F2.8 macro Sony FE 85mm F1.4 GM Sony FE 24mm F1.4 GM +5 more
Phil_Rose
Whatever people will pay me to! Weddings, portraits, real estate, product but, for myself I like nudes and landscapes (and nudes in landscapes). I feel like I might keep using APSc for a lot of stuff but FF would be great for my portrait and some of the wedding stuff (the wedding stuff that is more like portraiture!) Currently I use my Sony RX10iii for the shots of people dancing and so on at weddings because it is just so good and no one ever complains "that's a one inch sensor, YOU NOOB!' and the extra DOF is nice for fast moving subjects.
I like turtles.
klimbkat
klimbkat Senior Member • Posts: 2,659
Sigma 18-50 f2.8
Pentax 50mm 2.8
S/b FF
FF or very close
FF
FF
Pentax 60-250mm f4
Baffle vignettes at some f stops and focal lengths, but overall works well FF, about 90+ %.  I have not modified mine and use it regularly for portraits, live performances, etc.
Pentax 50-135 2.8
s/b FF
Phil
Even those lenses that are not FF will often give a large enough clean image circle to warrant using FF.  Given your selection, I'd suggest going for the K1 and the astoundingly good DFA 28-105 which will give you lots of time to play with your other glass.
Phil_Rose
Interesting. And would you advise going for the K1ii or getting the K1 and using the difference for lenses/food for my family?
Phil
I like turtles.
klimbkat
Phil
I was an early K1 adopter and did not do the Mk II upgrades as they seemed minor for my primarily landscape shooting, not enough to warrant the $500 difference. Of course, that also means I have no informed opinion on the changes or their relative value vs. the price difference. The DFA 28-105 is abou5 as good as a "kit" lens gets - great, clean rendition from which I've printed very big with zero issues. Always feed the family first . . .
Portrait with K1 and DA* 60-250
