Is the EF-M 11-22 short enough to use the built-in flash?
Started 2 months ago | Questions
drip01
drip01 Senior Member • Posts: 2,984
My EF-S 10-18 with the adaptor is too long and casts a shadow when using the M6II built-in flash ... wondering if the EF-M 11-22 can let the flash light go through completely.
Thanks in advance to 11-22 owners!
Brian
 drip01's gear list:drip01's gear list
Sigma 150-600mm F5-6.3 | C Sony a7R II Canon EOS M6 II Canon EF 70-200mm F2.8L IS II USM Canon EF-M 22mm f/2 STM +2 more
jalywol
jalywol Forum Pro • Posts: 10,052
Re: Is the EF-M 11-22 short enough to use the built-in flash?
On my M50, there is a shadow up to about 15mm, and none above that; just tried it in my living room shooting the couch from about 7 ft away.  Not sure if the M6II flash is any higher up on the body, but its position to the left of the lens might make the problem more pronounced...
-J
drip01
OP drip01 Senior Member • Posts: 2,984
-J
Many thanks to your info. Right, the lower right side of my pictures with flash is shadowed because the flash is on the left side. It looks like the 11-22 is not a viable solution to my problem. One way to get around this would be to move my focus to the left and crop out the right side, LOL.
Brian
JRET Contributing Member • Posts: 571
disclaimer - I haven't tested this thoroughly ...
... but through casual observations after using the built-in flash on the M50 it seems that using physically longer lenses often results in a shadow in the photo.  I'm pretty sure it's happened with me when using the 11-22, 18-55, and 18-150 but I didn't notice what focal lengths to avoid.   The 22 pancake should work without problems but using a flash attached to the hot shoe would likely be advisable when using larger (longer) lenses.
 JRET's gear list:JRET's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM +18 more
67gtonr Senior Member • Posts: 1,150
Can titling the flash upwards abit alleviate some of this?
 67gtonr's gear list:67gtonr's gear list
Canon EOS M Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM
jalywol
My suggestion would be to just pick up an inexpensive TTL flash for the hotshoe.  Even the basic ones will have bounce flash capabilities, and that would solve the entire issue.
-J
Sittatunga Senior Member • Posts: 1,662
11-22 with built-in flash results
I don't have an M6 II, so these are with an M100, 12mm shorter. The first time I've used flash with that lens; it definitely needs a more powerful flash than the M100's.
22mm 1/60 f/5.6 AutoISO 640, lens hood on
All pics of a white wall only 1.1m from the camera, AV mode, full aperture, flash white balance, room lighting from 5x60W incandescent bulbs. Distortion corrected but not vignetting.
22mm 1/60 f/5.6 AutoISO 640, lens hood off
17mm 1/60 f/5 AutoISO 500, no lens hood, slight shadow of the lens visible.
11mm 1/60 f/4 AutoISO 320, no lens hood
11mm 1/60 f/4 AutoISO 800, bounced from ceiling 1.6m above.
The different white balance of the last shot is due to the faster shutter speed - the room lighting was quite bright relative to the built in flash. I also took some pictures with my smallest flash, the 90EX. Plenty of vignetting even at 22mm and various amounts of shadow at focal lengths shorter than 14mm when the lens hood was fitted. My 430EX II was fine at 11mm even with the lens hood fitted, as long as I used the diffuser, and it was powerful enough to overcome the room lighting.
drip01
-J
But then where do I put the EVF???
Can someone invent a hotshoe splitter???
Brian
drip01
To answer both, I was trying to do a selfie in the dark, outdoors ... must need a ultra wide and nothing to bounce. Any solution for the future?
Brian
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 20,980
Depending on the flash used...
...you may see a darkening of the edges because the the limited angle of the flash lighting.  Most flash units (well, the ones I'm aware of) have a wider angle flash diffuser which is supposed to balance things out to wide angle specs.  However, there will still be times - depending on the scene - where the corners will be darker.
In those scenarios you can just deal with an option in most image editing programs called vignetting (I prefer the one in either LR or ACR).  With that editing option, you can bring up the edges and have them in line with the main part of the image - it's no biggie at all.
Now with a Fish Eye lens - well, that's a whole new ball game.
 Ben Herrmann's gear list:Ben Herrmann's gear list
Panasonic FZ1000 Fujifilm X30 Olympus E-330 Olympus OM-D E-M5 Canon EOS M +18 more
danblondell
danblondell Forum Member • Posts: 69
I believe the M6II has a flash similar to the M100. I use that exclusively by flipping it 90 degrees back with my finger. The light is more diffused and about 100x more pleasant. I believe that would solve the issue here too.
 danblondell's gear list:danblondell's gear list
Canon EOS M100 Canon EF-M 22mm f/2 STM Canon EF 50mm f/1.8 STM Kamlan 28mm F1.4
