M6ii Shutter Button Issue
Hoka Hey
Hoka Hey Senior Member • Posts: 1,283
The shutter button on my M6ii has a behavior that I'm not used to. When I half press, I meet resistance. Then, I have to press just a little harder to activate AF. On my R and 5D4, when I meet resistance, AF is activated without any need for further pressure.
Have other folks noticed this? If so, is it an issue or a feature?
Joe
Hoka Hey
OP Hoka Hey Senior Member • Posts: 1,283
Re: M6ii Shutter Button Issue
Bump.
I'm missing shots because the AF is not activating when I reach 1st resistance.
If you are not having this issue, please confirm that this is not normal.
Thanks.
Joe
R2D2 Forum Pro • Posts: 19,896
Mine feels just about right.
Can you AF without actually tripping the shutter?
R2
Sony RX100 II Canon EOS 7D Mark II Canon EOS M6 II
Hoka Hey
R2
Thanks R2.
I hit resistance. Then, I have to press a little more to get AF. Then I press firmly to trip the shutter.
I hit resistance and trigger AF at the same time on the R and the 5D4.
I had originally thought that AF was extra taking time to acquire focus on the M6ii. However, I now have figured out that I have to press harder to get AF. I think that have a bad unit and am going to send it back unless others are having the same experience and there is a good reason to have two different levels of "half-press."
Joe
davidgp
davidgp Contributing Member • Posts: 565
Joe
I've never noticed this. But lately I've been using back-button focus, so I'm not really paying attention to the half shutter point anymore. I'll check it out later this morning and let you know what I find.
-David
 davidgp's gear list:davidgp's gear list
Canon EOS 550D Canon EOS M6 II Canon EF 50mm F1.8 II Sigma 50-150mm F2.8 EX DC APO OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
R2
Thanks R2.
I have noticed that shutter feel varies somewhat between bodies (over the years).  See if you can try out another copy if this one doesn’t feel right though.
Good luck,
R2
Hoka Hey
R2D2 wrote:
R2
Thanks R2.
Good luck,
R2
Thanks R2.
Joe
E-M1XR Regular Member • Posts: 278
I can’t say I’ve noticed anything unusual on either of our units, but will double check. Could it be configured differently to the default?
davidgp
So, I tried this today.  I'm not sure I'd describe my camera's behavior as you do.  I found that it auto-focused as I reached the maximum resistance but not before, then extra force was needed to overcome the resistance and trigger the shutter.
This seems a bit different than my T2i, but very easy to use, so I have no complaints.  Though as I mentioned earlier, I'm currently using back-button focusing.
-David
filibuster
filibuster Veteran Member • Posts: 3,998
This garnered my curiosity, so I thought to try it first on the M6; then the M6ii. No discernible difference between the two cameras, with a simple light touch to the resistance point for the green box, followed by shutter actuation with a slightly firmer press.
If it ain't broke, fix it until it is!
filibuster (Bromsgrove, Worcestershire, UK)
Filibuster Script & Batch File Auto-Processing for Paint Shop Pro 2019
https://photos.app.goo.gl/4xDHgykzUu5H4Q7t7
Astro Turf the garden https://photos.app.goo.gl/GyeDrjncjKh1X7pJ8
Hoka Hey
Today, I realized that AF was going off and on even when I felt like I was exerting constant pressure on the shutter button.
I'm going to return the unit.
Thanks to all.
Joe
nnowak Veteran Member • Posts: 6,008
Thanks to all.
Definitely sounds like a defective unit.
Noogy
Noogy Veteran Member • Posts: 3,099
I noticed such hesitation in the first week I used the camera. It's gone now. Don't know if it's some kind of breaking in. I'm nearing two thousand shots now in my M6II btw if that helps.
"Photography is therapeutic."
https://500px.com/joshcruzphotos
 Noogy's gear list:Noogy's gear list
Canon EOS R Canon EOS RP Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF 16-35mm F4L IS USM +10 more
Hoka Hey
Thanks Noogy. My unit just doesn't seem right. It seems like it's getting worse instead of better.
Joe
Thanks to all.
That doesn’t sound right at all. Good idea on returning it.
