Should I use a tripod collar for 14-24mm FX lens
kokopuffs
kokopuffs Senior Member • Posts: 1,074
AF-S NIKKOR 14-24MM 1:2.8G-ED  This lens is awfully heavy and please pardon my inexperience with SLRs (my first one)
TIA
kokopuffs
 kokopuffs's gear list:kokopuffs's gear list
Leica D-LUX 4 Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Sigma 50mm F1.4 DG HSM | A +2 more
LordKOTL
LordKOTL Senior Member • Posts: 1,386
Re: Should I use a tripod collar for 14-24mm FX lens
TIA
The lens weighs 2.2lbs.  The Nikon 24-120 lens weighs more (2.65lbs) and doesn't need one.  A buddy shoots that 24-120 lens all the time.
I don't have solid proof of this, but it appears as it ~3lbs is the breakover point between needing a collar and not needing one (i.e. weights of lenses like the 70-200/500pf that come with a collar, and ones that don't).
I think you'll be okay without one.
Good luck and happy shooting!
There's no shame in using auto or semiauto modes--no matter what the salesdroids at Best Buy tell you.
 LordKOTL's gear list:LordKOTL's gear list
Nikon D750 Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon 85mm F1.8G Nikon AF-S Nikkor 20mm f/1.8G ED +3 more
larrywilson
larrywilson Veteran Member • Posts: 6,818
Not needed
 larrywilson's gear list:larrywilson's gear list
Nikon D7200 Nikon D850 Nikon AF-S Nikkor 500mm F4E FL ED VR Tamron SP 85mm F1.8 Di VC USD Tamron SP 150-600mm F5-6.3 Di VC USD G2 +7 more
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 17,689
I don't know if one exists. There really doesn't seem to be anywhere on the lens to attach one.
It is big and heavy but it's not terribly long.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony RX100 III Nikon D300 Nikon D750 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +12 more
larrywilson
One thing I do with a lens over a couple lbs. is pick up the camera and lens by the lens and avoid lifting the camera and lens from a face down position by the camera.  It takes a little more care with a heavy lens over 2 lbs. or so to avoid putting too much pressure on the camera mount.
Larry
kokopuffs
OP kokopuffs Senior Member • Posts: 1,074
larrywilson wrote......................One thing I do with a lens over a couple lbs. is pick up the camera and lens by the lens and avoid lifting the camera and lens from a face down position by the camera. It takes a little more care with a heavy lens over 2 lbs. or so to avoid putting too much pressure on the camera mount.
Larry
With said lens mounted but not in use I place the lens (with cover) face down on the desk. When I pick it up I lift by grasping both the lens and the camera strap. With your recommendation I'll lift the camera off of the desk by the lens only.
kokopuffs
IainD Senior Member • Posts: 2,266
I definitely agree with the posts above. No need and don't worry.
It is a very nice lens, but keep in mind Steve Perry's words
"Tools, not jewels!" Never advocating abuse, but don't get too concerned about using your gear.
Iain
BISCUT Regular Member • Posts: 166
I'm a happy enthusiast, not a pro.  I've always handheld mine and have some of my favorite kids pics from this awesome (yet huge) lens.  Haiti in 2016. 10, 8, and 5.
Gr8 lens!
 BISCUT's gear list:BISCUT's gear list
Nikon D850 Nikon Z6 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Nikkor 135mm f/2D DC Sigma 50mm F1.4 EX DG HSM +9 more
gnagel Veteran Member • Posts: 7,896
TIA
That is one of my most used lenses over the past decade. I always use a tripod, but never use a collar with that lens. There is really no need.
Glenn
Reggie Stration
Reggie Stration Regular Member • Posts: 385
The best authority to decide this are the Nikon experts who design their lenses. If a lens needs a tripod collar they typically include one. The 14-24 doesn’t come with a collar. Also, it’s a wide angle rather than a long tele where sharpness and a rock solid mount are more of an issue.
That said, though the newer version of the 80-400 does come with a factory tripod collar it is quite flimsy and flexible so on mine, I replaced it with the RRS collar which is vastly superior.
The 14-24 doesn’t need one but as always, a solid tripod and L bracket mount are highly advisable for critical sharpness.
Also though it is often referred to as a heavy lens, it weighs slightly more than the 24-70 2.8 and slightly less than the newer VR version of the 24-70, neither of which come with a tripod collar.
