Could this work in A2?
Started Dec 13, 2019 | Questions
eilivk Senior Member • Posts: 2,580
Kingston Elite Pro 4 GB 133x CompactFlash Memory Card CF/4GB-S2.
My Scandisc Extreme IV 4 GB did work fine, until I used it in another camera (more about that later)....
 eilivk's gear list:eilivk's gear list
Canon PowerShot G10 Ricoh GR Digital Fujifilm FinePix F200EXR Ricoh CX4 Sony RX1 +10 more
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Could this work in A2?
No reason why it wouldn't .
Put it in the camera , go into the menu and format the card .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
OP eilivk Senior Member • Posts: 2,580
Thanks! It's not here, but can buy it cheap. Thought maybe it was for more advanced cameras (pro).
neilt3
The A2 was the more advanced camera !
This was a few years ago after all .
Agree with that, more advanced! Still have not found out all, but at the same time userfriendly.
paul_kew Senior Member • Posts: 1,857
I thought I remembered that the A2 and Kingston cards didn't go well together , slow write speeds compared to other makes. It may have changed with later cards.
Some comments in this thread https://www.dpreview.com/forums/post/11794009  .
 paul_kew's gear list:paul_kew's gear list
Olympus OM-D E-M10
It worked ok! Came today, took some pictures, normal speed I think, no problems so far.
Still trying to unlock the Scandisc card, messages no matter what I try:
IndexerVolumeGuid
feilkode  (fault code) 0x8000000a
Any cure for this?
neilt3
IndexerVolumeGuid
Any cure for this?
I think your already running your camera on its latest firmware ?
See here ; https://www.konicaminoltasupport.com/index.php?id=2308&L=0%2Fi
To sort your card out , try what Hike Pics says here ; https://www.dpreview.com/forums/post/63297825
He had a card that was misbehaving and this sorted it .
IndexerVolumeGuid
Any cure for this?
Thanks! Latest firmware, and the new card is working fine. But to sort out the old card, I will try the Hike Pincs link. Had to admit I put the old card in an old Nikon and tried to format, without knowing too much about the camera. Did not work in Nikon and not in A2...
IndexerVolumeGuid
Any cure for this?
Before I found out what GPdeparted is I tried slow formatting after doing "gjenopprett enhetsstandarder" (renew ???standards) and it worked! Hooray! Two working cards, will check if they work in old Nikon and Canon. Or maybe one in reserve.
Thanks for all the help!
neilt3
Format the card before use in the camera it's to be used in and it should work just fine .
