What focal length for the most realistic pictures?
goodytwoshoes
goodytwoshoes Regular Member • Posts: 362
Oh yes, Rolleinut, there is and you should know ;-)
75mm 3.5 Planar 2nd Version
_______________________________________________________
Check out https://www.ecosia.org/
it may help this planet just a little bit !
 goodytwoshoes's gear list:goodytwoshoes's gear list
Leica Q2 Nikon D5 Canon EOS-1D X Mark II Sony a7R III Leica M10-P +17 more
goodytwoshoes
Zeiss Planars lead the way
... and then depending on the grade of enlargement and subject distance
you have to chose the appropriate f-stop.
SonyOB Senior Member • Posts: 1,015
Re: What focal length for the most realistic pictures?
Paul Barnard wrote:
Magnar W wrote:
Trollmannx wrote:
Assume one sees the Eiff (just as an example) and take a photograph.
Is the photograph realistic if it is:
- a sharp and well focused color image?
- a sharp and well focused black and white image?
- an unfocused - taken with a wide angle lens?
- taken with a normal lens?
- taken with a telephoto lens?
- an abstraction, showing traces of the Eiffel Tower?
- an abstract image, where the Eiffel Tower is not recognisable?
Natural size! And 3D.
Did you miss an 8 out in that size?
So realistic that you eat your SD card with a fine Chianti?
"Excuses. That's what you are creative with instead of putting your mind on not needing any".
 SonyOB's gear list:SonyOB's gear list
Sony RX100 V Canon EOS 5D Mark IV Sony a7 III Canon EF 50mm f/1.2L USM Canon EF 70-200mm F2.8L IS II USM +13 more
Stan Huntting
Stan Huntting Regular Member • Posts: 274
Re: Zeiss Planars lead the way
goodytwoshoes wrote:
... enlargement and subject distance
BINGO! Four pages into this thread and the other shoe finally drops!
Magnar framed the original question beautifully - too bad many contributors didn't read that post. But, what Magnar left out was any bounds on how the desired "natural" image will be viewed.
Are we to judge the naturalness of a captured image as a print, hung on the wall? What size print, how is it matted/framed and viewed from what distance? Is it displayed electronically? On a VR headset, the screen of a phone just beyond my face, a notebook display in my lap, a workstation display or a large 8K TV on the wall? Or perhaps, is the view through the EVF all that really counts.
My point is that (un)naturalness of any focal length/sensor size combination is a function of the viewed image size and viewing distance.
 Stan Huntting's gear list:Stan Huntting's gear list
Sony RX100 VA Sony a7R II Canon EF 400mm f/5.6L USM Sony FE 28mm F2 Sony FE 50mm F2.8 Macro +10 more
Entropy512 Veteran Member • Posts: 4,816
More than just the focal length.
Atypical optical structures not normally present in most camera lenses are required for realism.
Exact nature of these optical structures is highly variable. In my case, the required optics can no longer be purchased. https://www.zennioptical.com/p/rimless-flexible-memory-titanium/2164?skuId=216411 appears to be structurally similar to what is required to achieve maximum realism.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
Trollmannx Veteran Member • Posts: 6,062
Re: More than just the focal length.
In my opinion reality is needed for realism.
Photographs can be interpreted as more or less realistic despite beeing only a representation of the real thing.
My question: do photographic realism require camera lenses with those structures normally not present in most camera lenses to produce "realistic" images?
Vision should work the same way wether looking at reality or at images.
Just curious.
Rol Lei Nut Veteran Member • Posts: 4,935
Re: Oh yes, Rolleinut, there is and you should know ;-)
From the Rolleiflex 6x6 TLR?
Certainly a very nice interpretation of reality...
