A9 JPEG Moire and AF
vett93
vett93 Veteran Member • Posts: 4,867
I took an assignment to shoot a company holiday party last night. The requirement was to shoot JPEG and turn in image files shortly after the event. So I shot JPEG in Slot 2 and RAW in Slot 1, in case I needed to do PP. Most of the images turned out great with beautiful colors; i.e., no PP was needed.
There were a number of images that showed strong moire though. An example is shown below:
A9 JPEG OOC
I checked the RAW file and it looked fine.
A9 RAW file
The lens used is Sony FE 24-70/F2.8 GM.
Another thing worth noting is that while 90% of the AF worked great, about 10% of the time the AF struggled a bit. I used AF-S and Medium focus point. This was with the Sony flash HVL-F60RM's LED focus assitant light. I pressed the focus button, saw the LED light came on and off in the EVF, and then the focus point was still RED! This happened about 10% time. The other 90% time, the focus button would turn green quickly. The event was held in a restaurant and the light was dim.
The HVL-F60RM's LED focus assistant has two levels: high and low. I used the low level but I could sense it stilled bothered some people, as it was a bit too bright. Yet, the A9's AF had problems about 10% time. Do I have unrealistic expectations?
"Keep calm and take photos"
Photography enthusiast, from 12mm to 600mm
 vett93's gear list:vett93's gear list
Sony a9 Sony a7R III Sony a6500 Apple iPhone 11 Pro
Sony a9
TheOwl360 Regular Member • Posts: 280
Re: A9 JPEG Moire and AF
A9 JPEG OOC
A9 RAW file
Thanks for sharing this. Its helpful.
 TheOwl360's gear list:TheOwl360's gear list
Sony RX100 VII Sony a7R III Sony a9 II Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Carl Zeiss Apo Sonnar T* 2/135 +13 more
