Repairing Black Finish Scratches
Started Dec 12, 2019 | Discussions
landscaper1
landscaper1 Veteran Member • Posts: 5,223
If you're like me, you try to keep your photo gear looking as new as possible against the day you may decide to sell it.  I recently found a 2 inch long white scratch on the outer barrel of a long tele zoom lens that was finished in flat black.
Thinking about how best to minimize that scratch I remembered I had a bottle of Turtle Wax Color Magic Car Polish - Black in my store of auto supplies.  Now, the bottle says it's not recommended for flat finishes, but you can disregard that for this.
(1) Wipe the scratch area with alcohol to remove any finger print oil.
(2) Mask around the scratch with Scotch Magic Tape (or the equivalent).  The idea is to minimize the unscratched area that the Color Magic will be applied to.
(3) Apply a small dab of the Color Magic to a soft cloth (like an old handkerchief) and firmly rub that into the scratch using various strokes to get a thorough coverage.
(4) Allow the Color Magic to dry to a haze (15 to 20 minutes depending on the humidity of the air).
(5) Gently remove the masking tape and buff off the haze.
The results look pretty darn good.
Landscaper
"Draw me a picture of an island without any seas;
show me a map of the whole world without boundaries."
 landscaper1's gear list:landscaper1's gear list
Canon EOS R5 Sigma 50mm F1.4 DG HSM | A Sigma 20mm F1.4 DG HSM Art Tamron SP 150-600mm F5-6.3 Di VC USD G2 Venus Laowa 12mm F2.8 Zero-D +3 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: Repairing Black Finish Scratches
Flat black is usually anodized black aluminum.
The best repair I know of for that is BIRCHWOOD CASEY Aluminum Black. This is wiped on with a Q-tip and basically reacts with the raw aluminum to produce a hard black finish. It might take a couple of coats, depending on the type of aluminum. A little bottle costs less than $10 and will cover an amazing amount of use.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
HRC2016 Veteran Member • Posts: 6,874
I'd just use a black Sharpie.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
ProfHankD
I used to do that... but:
  • Black Sharpie is actually not black, but very dark purple.
  • It doesn't really stick very well to raw aluminum and does stick to paint/anodizing, casting it shinier and purplish.
Before I found Aluminum Black, my other fix was black acrylic paint filled-into any scratch or gouge. Acrylic paint also works well for refreshing engraved lettering. The result is durable, yet can be deliberately removed quite easily, so it's still a good option if "prettying-up" a lens that might have significant collector value with the original finish.
Bonzodawg New Member • Posts: 1
Just use an indelible marker pen, a fine point can disguise small scratches well!
Bonzodawg
landscaper1
OP landscaper1 Veteran Member • Posts: 5,223
Bonzodawg
Not the best solution. First, it's not truly black; more like a very dark purple that's visible in bright light. Second, it's not permanent; it can be dissolved eventually by skin oils.
Landscaper 1
"Open up your eyes and look around you.
There's a lotta world you've never seen.
They've got the sights that will astound you.
You CAN go there; you CAN see your dreams."
-- Pan American Airlines radio jingle (c1980)
