You can only select a zoom lens. Which?
Started Dec 11, 2019 | Polls
fernandojval
fernandojval Regular Member • Posts: 428
If you could only have one lens, which of these zoom lenses would you choose?
Thanks for your answer.
 fernandojval's gear list:fernandojval's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Tamron 17–70mm F2.8 Di III-A VC RXD +3 more
POLL
Fujinon 18-55mm f2.8-4
28.1% 43  votes
Fujinon 16-80mm f4
17.0% 26  votes
Fujinon 16-55mm f2.8
54.9% 84  votes
  Show results
Clive99 Senior Member • Posts: 1,389
Re: You can only select a zoom lens. Which?
5
You need to narrow this down for different applications/types of photography.
 Clive99's gear list:Clive99's gear list
Fujifilm XF10 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 18mm F2 R Samyang 8mm F2.8 UMC Fisheye +16 more
hwchiu Regular Member • Posts: 269
It is the 18-55. How about also including 15-45 & 16-50? I have the 18-55 & 16-50. Both perform to my satisfaction.
fernandojval
OP fernandojval Regular Member • Posts: 428
Ok. Street photography, family report, studio photo and travel photographic photography.
fernandojval
I only think of those three lenses. I do not want others. Thanks for your reply.
Len-O Senior Member • Posts: 1,637
Your question as asked with regard to general purpose zooms, for me only leads to the 16-55/2.8.
Once you add in reach capability you have another bunch with different specs to choose from.
 Len-O's gear list:Len-O's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +8 more
DocetLector Contributing Member • Posts: 934
I use only one zoom lens - the 16-80.
Bought it last week and I am very satisfied with the results. My other 2 lenses are the 35/1.4 and the Zeiss Touit 12/2.8.
I still have the 18-55 because I might use it one day together with my Xe2s when I want light and small.
 DocetLector's gear list:DocetLector's gear list
Canon G1 X II Canon EOS M6 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM +5 more
Keithpictures
Keithpictures Contributing Member • Posts: 832
Travel
7
Photographic photography is my favorite ✈️
 Keithpictures's gear list:Keithpictures's gear list
Leica C-Lux Fujifilm X100V Apple iPhone 13 Pro
deednets Forum Pro • Posts: 13,887
None of the above
I would rather do studio, travel, architecture and landscapes with one prime.
A bit narrow to simply put 3 zooms up as choices.
I could give you gazillions of examples where I have used just one prime for the above mentioned applications, so have some idea what I could do with just one lens.
Good luck with your choice
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
curiouspeter Regular Member • Posts: 252
Zooming by feet and by cropping with my XF16mm f/1.4... if I can bring only one lens for street and travel.
jjz2 Veteran Member • Posts: 4,396
Are you asking if it’s the only lens you’ll have? If so the 16-55. If not, I’d base it on the other lenses you have.
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
biza43 Forum Pro • Posts: 15,074
For me, prime lens.
studio photo
Depending on size of studio: prime lens, 50-140 zoom, or both.
Prime lens.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
jhorse Veteran Member • Posts: 5,913
I agree and I'd add budget.  That said, I did vote.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
fernandojval
Re: Travel
This happens when I use the google translator. Thanks for your reply.
brokenhat
brokenhat Regular Member • Posts: 468
16-55 is the best for stills but the heaviest and most expensive. No OIS really hurts for video. If you were treating me it would still be my choice though
Matt
 brokenhat's gear list:brokenhat's gear list
Fujifilm X100V Fujifilm X-Pro3 Fujifilm XF 35mm F2 R WR Fujifilm XF 16mm F2.8
My favourite zoom is the 10-24.
If I had to pick one, I'd probably pick the only one I decided not to get..the 16-55F2.8
Canyongazer Regular Member • Posts: 441
An OP asks:
"Which of these three Ford pick up trucks should I get?"
Ford Lariat?
Ford 150?
Ford KIng Cab?
DP gang replies : Ford Mustang.
 Canyongazer's gear list:Canyongazer's gear list
Fujifilm X100S Fujifilm X-Pro2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 16mm F1.4 R WR +10 more
technotic Contributing Member • Posts: 792
100-400 gotta be.
fernandojval
Canyongazer escribió:
Un OP pregunta:
"¿Cuál de estas tres camionetas Ford debería comprar?"
Ford Lariat?
Ford 150?
Ford KIng Cab
La pandilla DP responde: Ford Mustang.
This is always the case.
Come on, keep voting!
John Gellings
John Gellings Veteran Member • Posts: 9,743
If I’m only allowed to have one...and I have to use it for everything... the 16-55mm 2.8.  But since I don’t have that restriction... I’ll buy the 16-80mm F4 for when I’m not using my primes.
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
