Panasonic 14mm f2.5?
Started Dec 11, 2019 | Questions
BluenoseNS
BluenoseNS Regular Member • Posts: 455
Hi, I have the 17mm f2.8 Olympus lens that came with my old epl-3 camera.
I love the lens, but now there are many better options.
Inhave my eye on the cheap Panasonic 14mm f2.5, but I wonder if the optical quality is only marginally better than the 17mm f2.8
Anybody have experience with the 14mm f2.5?
I do outdoor, ‘street’, and friend and family gatherings etc
I don’t see too much about this lens on the net, and I’m worried that it is basically Panasonic’s version of the Olympus 17mm f2.8
I want a better optical quality than the 17mm f2.8
 BluenoseNS's gear list:BluenoseNS's gear list
Olympus PEN E-P5 Olympus PEN-F
Panasonic Lumix G 14mm F2.5 II ASPH
AndyH44 Veteran Member • Posts: 3,112
Re: Panasonic 14mm f2.5?
Sold the 14 f2.5 II that I had as the edges and corners were mushy.  Kept my 18 f2.8 as it was more than "marginally better" and produces great images SOOC.
Hoping to get better optics at a cheap price is fruitless.
"The world doesn't exist to satisfy our expectations."
aliasfox Senior Member • Posts: 1,375
The 14/2.5 is a fine lens for what it is - an inexpensive, tiny lens. It won't win any awards for its rendering, but I've never had any concerns going out with mounted on any of my bodies. If I had to say something about the rendering, I'd venture that the lens isn't super contrast-y, and you have to work a bit more in post to get your images to pop.
If you're looking strictly for the smallest autofocusing lens you can get, I'd grab one - if you mount it on an E-PL or a GX850 you end up with a camera with similar photographic chops to a Fuji X70, in only a slightly bigger package.
If you're looking for better rendition, I'd look at either the PL 15/1.7 or the Oly 17/1.8 instead. These are both bigger and heavier lenses - about twice as big as the 14/2.5 - but are definitely better. By reputation, the 15/1.7 is sharper than the 17/1.8, but between my 17 and my wife's 15, there isn't anything between them. I personally prefer the rendering of the 17, though I may be biased (I prefer 24mm and 35mm perspectives, don't like 28mm as much).
The PL15 still commands a relatively steep price, but I've started seeing used prices on the 17/1.8 fall a bit (probably due to pressure from the PL15), and while it's more than the Panasonic 14/2.5, it's not extravagantly so if you're lucky.
One lens I would personally avoid for street shooting and family gatherings is the Panasonic 20/1.7. It's a very sharp lens and quite compact, but the AF performance leaves much to be desired. The 15 and 17 are quick with the AF (the 17 is lightning fast), and the 20 could be judiciously called "leisurely." However, it makes for a great still-life lens (museums, posed pictures of family/friends), so may be worth collecting at some point.
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
Yar1971 Regular Member • Posts: 410
P. 14/2.5 (I or II, no matter) has nothing to do with O. 17/2.8. Both a totallly different lenses, especially in the aspect of focal length. You may check their specifications (including optical design/scheme) at www.lenstip.com Note, 14/2.5 I and 17/2.8 were also tested there.
17.2.8 has slightly bad reputation from this test/review as far as I know due to high level of chromatic aberration. 14/2.5 optical quality was considered quite well.
I have P. 14/2.5 (I) and O. 17/1.8. Not the same lens in the second case, but the same focal length and (consequently) field of view.  Both were used mostly as a fast(ish) prime for interiors.  I prefer more 17mm now, because it's more universal for me. In spite of longer focal length is easier to use in the dark, due to significantly better F/stop. There's little difference between F/2.5 and F/2.8. So comparing 17/2.8 to 14/2.5 in the aspect of low light use, the shorter lens is the winner here.
-J.
BluenoseNS
OP BluenoseNS Regular Member • Posts: 455
Thanks for all of your thoughts. I may look into a used 17mm f1.8...
jdu_sg Regular Member • Posts: 269
Here's a good sharpness test report of several lenses that are in the mix with your current lens.
https://www.lensrentals.com/blog/2012/05/wide-angle-micro-43-imatest-results/
The 14/2.5 shows better than the 17/2.8.
There is nothing better at that (new) price with AF near that FL. If you want to five on one of those parameters, there are some choices.
If it was me I'd have a long hard look at the Pan Leica 15/1.7 even if the shutter ring is non-functional on Oly. The Oly 17/1.8 *may* not be as good optically, but it does have the focus ring. I am partial to physical lens controls because they make picture taking a lot easier.
 jdu_sg's gear list:jdu_sg's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Rokinon 8mm F3.5 Aspherical Fisheye +4 more
BluenoseNS
Thanks for the link! I’m now going to search for a used 17mm...
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
One issue with the 17mm f1.8 is field curvature. This makes it difficult to get sharp photos across the frame - not the greatest for group photos. I have used it and I did not buy it. I bought the 15mm f1.7 instead.
Last year I did a side - by - side comparison of the 14mm f2.5 at f2.5 vs the 15mm f1.7 at f1.7. Regarding sharpness, I do not see any difference - even in the corners. See the photos below. (Ignore the slight difference in exposure).
Another lens you may want to look at is the 12-32mm. I also did a comparison with this to the 14mm and did not see any difference at 14mm. I use the 12-32mm a lot for street photography and it works well. The 12-32 is a good lens while not as fast as the others, it is stabilized and very small.
So, the 14mm is a good lens and is the smallest and better suited for groups but do look at the 12-32mm.
Allan
Panasonic 14mm f2.5 @ f2.5
Panasonic 15mm f1.7 @ f1.7
august02
august02 Junior Member • Posts: 37
I have had the 14/2,5 mk I since 2010. Did not like it for the first five years.I have always had, but never used the 28. My favourit has always been the 40mm (20mm in mft) lens.In 2019 I forced my self to use it more frequently and found it superb for street photography.
 august02's gear list:august02's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G 14mm F2.5 ASPH +6 more
BluenoseNS
Allan
The 15mm f1.7 looks fantastic, but is currently $750 Canadian!!
For me, that is firmly in the ‘camera body cost’ slot
I have a new pen f being shipped to me, so the 15mm f1.8 May have to wait.
DDoram
DDoram Forum Pro • Posts: 10,369
While I don't have the Oly 17mm the Panny 14mm pancake is a solid lens.
Dale
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
Barry Twycross Veteran Member • Posts: 4,780
I just never liked the 14/2.5, I prefer the 12-32. The 12-32 was marginally sharper in my tests, I often use it as a compact 12/3.5 (with stabilization). The rendering of the 14/2.5 just seemed unexciting, and I prefer the 12 focal length anyway.
 Barry Twycross's gear list:Barry Twycross's gear list
Olympus E-PL7 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Fujifilm GF 110mm F2 Venus Laowa 7.5mm F2 MFT +11 more
inlawbiker Senior Member • Posts: 2,066
The 14mm is kind of a forgotten lens. I think it's a "must own" but others probably disagree.
Why? It's the smallest lens in the platform unless I'm mistaken and I love small lenses. It is also one of the sharpest lenses I've ever used. I tend to shoot it around f5.6 in the street, where 28mm is really useful. Another bonus is how inexpensive it is. For great for specific cases where size and stopped-down sharpness are valuable.
On the other hand that also limits its usefulness. It's not a very versatile lens. For friends and family gatherings you probably want something faster. 2.5 isn't very fast and it's better stopped down anyway, so for people there are better choices, like a 17 or 15, or even the (really large) Sigma 16mm 1.4.
It is better than the 17 2.8 for sure, just be sure that you're using the right lens for the right application. Actually there isn't anything wrong with the 17 either if you stop it down.
Greg
 inlawbiker's gear list:inlawbiker's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Gnine Senior Member • Posts: 4,108
Not sure why people say it's mushy. I rather like mine. It's not cheap, to buy new in my country, but I think it suffers a bit from kit lens syndrome.
I added the vignette
alcelc
alcelc Forum Pro • Posts: 19,004
15 f/1.7 might be the answer?
14, quit an old lens, does not have a really fast speed, IMHO its IQ is neither outstanding (reasonably good) nor bad ...
IMHO under the general tendency of Oly shooter would have a first preference on Oly lens, such lens would normally picked up by Panny shooters (of course there are always exceptions). As a non outstanding lens nor has anything special, its owner base would be limited.
I also suspect that like myself, many of its owners got it as a kit lens with a Panny body. As Panny only adopt IBIS on recent models, a f/2.5 non OIS lens indeed cannot use slower shutter speed than a  f/3.5 OIS lens on a non IBIS body. Compounded by the good quality of Panny consumer grade zoom that is closed to 14 in real life (at least true to my copy), hence except for its pancake design or low cost, it has nothing standing out in the old days.
I suppose those are major reasons for 14 has never received warm welcome as its siblings e.g. the 20 f/1.7 or those f/1.8 lenses from Oly.
I have it for many years since G1's day, rarely use it. But for a compact low cost and reasonable IQ wide angle lens, not a bad option at all.
Albert
tomhongkong Veteran Member • Posts: 4,723
I find that the 14 stopped down just a touch is very sharp.  I can't compare with 17/2.8 but reviews of that lens are not great.  Don't be confused by the comments about the 12-32 (which is a great lens, by the way) Its stabilization adds nothing when used on your Olympus body, so the 14 is still faster and (used as I suggest above) sharper.
tom
nevada5
nevada5 Forum Pro • Posts: 15,569
I had one and I liked it.  It's a sharp lens.  I only sold it b/c I preferred a longer FL for an all-purpose lens.  I use my 20mm f/1.7 a lot.
If the FL suits you, get it.
I'll try to be nicer if you'll try to be smarter.
Life is short - drive a convertible.
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Re: Panasonic 14mm f2.5 vs 17 2.8
I have onwed both lenses, on a panasonic body it is the better lens.
it works with no problem and focuses well.
It is a different focal length, so you really want the 14mm for the focal length and not for the optical output, because you may want a 17 for that focal length.
The output is on par with the 17 if choosing manual focus, otherwise in AF 14 is a winner.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
carlgorski Contributing Member • Posts: 861
Sold mine. Not very good.
todays samples
Just in case my memory was failing me, I popped the 14 on my G9, tossed in in my backpack, went for a pedal, & shot a few frames with it. Are there sharper lenses out there? One would probably say yes. But I reckon it does splendidly, even shot wide open. With later bodies capable of 1 second exposures, it should work very nicely in very low light situations. f/2.5 is just enough to slightly soften the background, & give a tiny bit of a 3D look. AF is fast, confident, accurate & quiet. For what they go for second hand, worth having in your kit.
It can handle flying down these tracks at 35 odd km/hr, launching into the air and landing gracefully. Has to, to earn a place in my kit
I don't think Tom is the local concreting contractors favorite person
