How to Change the Playmemories Home Folder Date Format
Started Dec 11, 2019 | Discussions
BrentSchumer
BrentSchumer Senior Member • Posts: 4,663
I use PlayMemories Home for photo import from my cameras and was always annoyed that the folders were created as MM-DD-YYYY despite my cameras being set up to use YYYY-MM-DD.  I prefer the latter for chronological sorting. So every import was followed by folder reformatting.  Not a big deal but - as you might have noticed - I get frustrated by things that are less useful than they could be.
After some online research I read that PlayMemories formats the folders based on your system date formats.  If you change Windows to use the YYYY-MM-DD format all your folders will follow.  Thought I'd share this method for anyone else experiencing a similar frustration:
1. Right click on your lower right hand system clock and select "Adjust date/time"
2. In the date and time control panel, click on "Date, time, & regional formatting."
3. There is an option at the bottom of Region called "Change data formats."  Almost done!
4. The folder format used by PlayMemories Home is the Short Date.
They're so beautiful!!
 BrentSchumer's gear list:BrentSchumer's gear list
Sony RX100 VI Sony a7R III Venus Laowa 100mm F2.8 Macro Tamron 20mm F2.8 Di III OSD Tamron 28-200mm F2.8-5.6 +1 more
OWLVIP New Member • Posts: 2
Re: How to Change the Playmemories Home Folder Date Format
Brent, thank you for your great posting.
Indeed, it works but only after I changed to country USA do I have the option of YYYYMMDD in the short date.  It could work for other countries too albeit with English (Singapore) which is where I reside, the option of YYYYMMDD for short date is not available.
Not sure if there are other workarounds.
BrentSchumer
OP BrentSchumer Senior Member • Posts: 4,663
Glad it helped!
