70-300mm to 70-350mm, anyone switched?
MarkG Regular Member • Posts: 332
I'm curious about the first-hand experiences of the owners of FE 70-300mm who switched to E 70-350mm. Preferably on a6300 or later body (a6400 or a6600 would be ideal).
I'm sure you are enjoying weight/size savings...
* Do you see any AF speed improvement in AF-C?
* Do you see any IQ difference at 300-350mm wide open?
* Do you miss focus limiter?
* Do you miss closer focus distance?
* What about 1/3 stop difference?
I have a very good copy of the 70-300mm on a6400 and enjoy it quite a bit. Wondering if anyone switched and what you think after you did that.
Thanks!
 MarkG's gear list:MarkG's gear list
Ricoh GR Sony RX100 VI Sony a7S Canon EOS M50 Sony a6400 +9 more
Sony a6300
paul wassermann Senior Member • Posts: 1,636
Re: 70-300mm to 70-350mm, anyone switched?
Thanks!
I just pulled the trigger on the $900 70-350 today.  I sold my 70-300 after I ran a comparison to the 70-200 which proved to be sharper at matching focal lengths.  Looking forward to comparing the 70-350 A6400 to my A9 70-200.
 paul wassermann's gear list:paul wassermann's gear list
Sony a7R II Sony a9 Sony a6600 Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM Sony FE 90mm F2.8 macro +6 more
lovehifi Contributing Member • Posts: 716
Tried two copies but gave up when both were defective or something. I rarely could get focused shots at the long end if the subject was moving. I have zero issues with my 100-400mm. Maybe needs a firmware fix or something. When both did focus correctly at 350mm neither was near as sharp as my previous 70-300mm but it was an excellent copy. Really wished it had worked out. I tried both copies using an a6500 and A7RIV.
OP MarkG Regular Member • Posts: 332
Thanks!
Well, 70-200 should be sharper than 70-300. Looking forward to your experiences of the 70-350 on a6400.
Well decided to go ahead and try a third copy in hope that my first two were just defective or not so great copies. They both probably came from the same batch. It was like there was something wrong with the IBIS when using both zoomed out. I remember on both there was extreme shake and motion blur even when taking shots of still subjects at 350mm.  Hoping three times is a charm. Others really seem to like the lens. If not then it will go back too. I did love the weight and size when I tried them. We shall see.
C.Eaton
C.Eaton Senior Member • Posts: 1,048
Thanks!
Like yourself I have the FE 70-300 and was considering the switch to the 70-350, however Mark Galer reported that the AF was no different between the two despite the uprated system in the newer lens.
Also I like the idea of getting an A7 of some flavour and obviously I can switch between, so the FE lens is staying.
 C.Eaton's gear list:C.Eaton's gear list
Sony Alpha NEX-6 Sony a6400 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony FE 70-300mm F4.5-5.6 G OSS
Zductive Regular Member • Posts: 231
Other threads report an AF problem when zoomed above 300mm.
 Zductive's gear list:Zductive's gear list
Sony a6000
