Get rid of circle in Live View Focus 5d iv
tsinsf Contributing Member • Posts: 676
I changed some settings and now have a circle the middle of my Live View screen and I can't figure out how to get rid of it. Can anybody help? Thanks.
 tsinsf's gear list:tsinsf's gear list
Canon EOS 5D Mark IV
Bestwun2
Bestwun2 New Member • Posts: 14
Re: Get rid of circle in Live View Focus 5d iv
The only circle I've seen is for Spot metering?
1Dx4me Senior Member • Posts: 7,841
when all else fails, read the manual
You miss 100 percent of the shots you didn't take!!! "Wayne Gretzky"
OP tsinsf Contributing Member • Posts: 676
Thank you so much for your helpful reply. Circle in the middle of my Live View screen is not in the index and after twenty minutes looking for help I gave up.
HeikkiS Junior Member • Posts: 46
I have found that in some cases Douglas Klostermann's 5DIV guide is quite helpful.
During both Spot and Partail Metering there is a Circle in the LV.
 HeikkiS's gear list:HeikkiS's gear list
Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM
Holscen Contributing Member • Posts: 654
More detail please...
....is it anything like this problem with a sigma lens?
https://www.dpreview.com/forums/thread/4227550
 Holscen's gear list:Holscen's gear list
Canon EOS 5D Mark III Canon EF 85mm f/1.8 USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM +4 more
meigas New Member • Posts: 16
There's always one!
Johnbro Regular Member • Posts: 225
This.
Turn on LV. Press the Q button and select different metering modes. You'll see the two middle ones (Spot and Partial) outline the metering zone with a circle (so you know what you are metering on). Evaluative and center-weighted use the entire image area, so no circle is needed or shown.
 Johnbro's gear list:Johnbro's gear list
Canon EOS 50D Canon EOS-1D Mark IV Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 85mm f/1.8 USM +13 more
Mika Y.
Mika Y. Senior Member • Posts: 1,295
Can you share a photo of the screen to show what the circle looks like? Other than the circles already mentioned for some metering modes I can't think of anything I've seen, but seeing what it looks like exactly could help.
 Mika Y.'s gear list:Mika Y.'s gear list
Canon EOS 40D Canon EOS 5D Mark III Canon EOS Rebel T4i Canon EOS 5D Mark IV Canon EF 50mm f/1.4 USM +14 more
CameraCarl Veteran Member • Posts: 6,744
Have you tried resetting the camera to all the factory default settings?
By the way, you're not thinking of the electronic level which has a circle in it?
OP here. Thanks for all the responses. The problem is solved. As suggested above, I had somehow switched from evaluative to spot metering, which creates the circle. I switched back to evaluative metering and the circle is gone.
