Colors are flat (indoors, Procapture, Oly M1.II)
Started Dec 4, 2019 | Questions
techie takes pics Senior Member • Posts: 1,730
I can't get control of this yet.
Look at the histogram: Only some 60% of the dynamic range is used, and I don't understand why.
This happens on the Olympus M1.II, especially in ProCapture silent mode (electronic shutter).  I experimented with light measuring on default (ESP) and center-weighted-average.   This is indoors with fluorescent lighting.
It's on shutter priority and Auto-ISO with a max of 6400.
The histogram does not fill out to the right, and I don't understand why.  Iso isn't maxed out (it's 1250), not even the background is properly exposed.
Any clues?
 techie takes pics's gear list:techie takes pics's gear list
Olympus PEN E-P5 Olympus OM-D E-M10 II Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +8 more
Skeeterbytes Forum Pro • Posts: 23,182
Re: Colors are flat (indoors, Procapture, Oly M1.II)
Definitely underexposed. I wonder if ProCapture is having issues with the fluorescent lights strobing? Are you using PC low or high? High locks everything at first frame while low adjusts focus and IIRC exposure during the sequence.
Is the meter perhaps reading the white(?) background and setting to that?
Do you have any standard high-speed drive sequences to compare against? My experience under stadium lights is adjacent frames showing variations in both exposure and color balance due to light cycling. I don't use Pro Capture for sports so cannot compare directly. For this setting I'd probably set exposure in M mode and either anti-shock low or e-shutter low drive, C-AF with lock at +2.
Good sleuthing!
Rick
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
There are situations when the camera meter just fails for some reason. That's when you need to look at the histogram (when shooting) and dial in a few stops of correction.
I think the large light-colored background may throw off the camera, although it should not be that much. Generally, if your subject is darker in front of a lighter background, some +EV is needed, despite advanced metering modes.
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
stateit
stateit Senior Member • Posts: 1,741
That white background looks a very respectable mid-grey.
Maybe set manual exposure for the white background?
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,214
6
Agreed.
White backgrounds are always a problem, because the metering will try to expose it as a medium gray.  Exposure compensation becomes essential.
You can also have a problem with colors if you set the camera color space to anything other than sRGB.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
Astrotripper Veteran Member • Posts: 8,676
What's your base curve? Maybe by some chance Darktable did not apply the default one it usually applies to Olympus raws?
In general, Olympus sets up their cameras to protect highlights. The base curve is very steep to stretch the middles while maintaining highlights. But that also is a massive waste for scenes of low dynamic range.
Also, like others have noted, it's very likely your shots are simply underexposed, on account of that light background that would trick the metering.
BTW, I have a permanently set 2/3 stops metering bias on my E-M1 II and I very rarely need to use negative exposure compensation. This saves me the trouble of worrying about situations like yours.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
OP techie takes pics Senior Member • Posts: 1,730
I agree, it definitely looks underexposed.
I just can not understand why. With automatic metering it should expose so the darkest part is black and the brightest part is just maxed out. I would never expect it to expose from grey to grey.
Background: Thanks for the tip of looking at the background - it does indeed expose as uniform grey when it's in fact nearly white.
Basecurve: Answers on valid questions: Darktable Alternate Olympus basecurve. It picks this one by default. Usually on single shots, or outdoors, this works fine.
Here is another shot which worked out a lot better. This is again Procapture Electronic shutter, but the background is slightly different - not a uniform white-ish color but largely unlit spectator seats.
Shot has the same metering mode as the other one - center weighted average.
There is still a considerable grey wall below the seats.
Actually that wall really is grey, not near-white like the other one.
Note there is a very over-exposed light in the background - the camera clearly does not take that as a reference for exposing the rest of the image.
Actually, most shots from this location had their histograms filled out quite well.
Mark Ransom
Ideally, that's exactly how it would work - automatic ETTR.  Somehow the camera makers haven't figured out yet that that would be a good thing.  Of course that wouldn't be perfect either, as your example shows - a bright light really should be overexposed most of the time, and the camera has no way to know that.
Since assuming the meter is pointed to a medium brightness object has worked good enough for so long, it seems it's not going to change any time soon.  It's up to you to know when exposure compensation is required.
Lichtspiel
The difference here is that your subject fills a larger part of the frame, and therefore the camera meter/logic has something to grab besides the background.
Plus, as you say, this wall is grey, so it will be exposed correctly. Exposure is (and should) not always (be) maxed out between shadow and highlight. There is some averaging going on, sometimes you end up with underexposed shots, sometimes overexposed highlights. Sometimes you need to dial in +EV, and sometimes, like in this example, the overexposed light doesn't matter. In a different shot, it may, and then it is time for -EV.
stateit
There is certainly one constant in your images. The background. The second constant I'd imagine throughout each routine as well is the lighting. Each set of apparatus is constant for each routine as well.
Near perfect photographic bliss.
So the only thing that changes really is the subject doing the routine.
Spot Meter for the background to show as the white it is (I'd guess EV+1.5).
Or find a mid-grey or neutral tone somewhere to spot meter from with +/- 0 EV.
Press the A-EL button to set exposure lock, then snap (or Pro-Capture) away.
It won't matter if the subject comes out wearing all black, all white, or wearing pink and green polka dots. All your exposures will be good.
Very good point, Very obvious but I hadn't considered it yet.  I was focussing too much on getting the auto-exposure to work correctly.
It would be the same if I simply dialled in a manual exposure, I guess?
stateit
Exactly. Manual mode/exposure may seem  may seem complicated, but it can actually make things a lot simpler.
CharlesB58 Veteran Member • Posts: 9,829
Reflective meters in cameras are calibrated to 18% grey. Even ESP/multisegmented metering just compares scores of 18% grey readings and guesses at what the best overall exposure is.
Also, white balance setting can throw a meter off when you have certain types of light. Is your WB set for fluorescent or custom? Auto WB could contribute to the exposure being off.
Since your camera has an EVF, it can be set to W"You See Is What You Get" and you can actually see a pretty accurate representation of how the captures image will look.
Photography is not about the thing photographed. It is about how that thing looks photographed. Quote by Garry Winogrand
http://ikkensimages.com
Bassam Guy Veteran Member • Posts: 4,885
Good sleuthing!
Rick
Agree. Way underexposed. With that huge white background, pull it up at least 2 stops. Better yet, ignore the meter and adjust exposure by watching LV in the EVF (or display).
It is RAW, and there is enough detail, to recapture the moment by pulling up the exposure in the well-respected Dark Table (which I've never used).
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
alcelc
alcelc Forum Pro • Posts: 19,003
Good sleuthing!
Rick
I don't use Olympus bodies so have no knowledge on Pro Capture.
AFAIK Pro Capture is sort of high speed shooting similar (but in different method of handling) to the 4K/6K Photo mode of Panasonic?
Under the 4K/6K Photo modes, shooter has the absolute power to control the setting like still shooting. So, it is making use of the P/S/A/M video mode, 30/60 fps shooting speed, e-shutter and saves the output in MP4.
If Pro Capture operates similarly (except using still burst shooting instead of video footage fps, output in RAW + jpg instead of MP4), no reason the sort of underexposure will happen (save for shooter setting error). So, does Pro Capture operates in similar operation as Panasonic's 4K/6K photo mode or on automatic only?
Albert
Good sleuthing!
Rick
ProCapture is a total photo mode. AF, exposure, mechanical or electronic shutter - the works.
It starts making photos when you half-press the button but only keeps them buffered. When you full-press it writes the pictures to the card.
Usecase: I see a gymnast getting ready for a jump. I half-press the SB. Camera starts shooting at 15FPS, with autofocus on every frame. She waits, thinks, pauzes... you get the idea. And then she jumps.
I think 'Good jump' and gently press the SB.
The camera now saves 10 frames from before I pressed the button.
Even though the exact moment surprised me, I have the entire jump captured at 15FPS. In Raw.
Had I done this on normal continous mode, it would have written 30-50 seconds of useless pictures to the SD card. At 15FPS.
alcelc
Thanks for the info. It reinforce my understanding on Pro Capture. It is doing in similar principle of the Pre Burst mode of Panny's 4K/6K Photo mode.
So, if the exposure parameters had been set right you should have a perfectly exposed sequence of image.
Albert
s_grins
s_grins Forum Pro • Posts: 14,011
From clueless to Techie,
What was the light inside these doors? What was WB and Color space? Maybe my questions bring some clue
And, if you post your question with RETOUCH forum, you have a great chance to get amazing explanations and solutions.
Cheers
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
Cheers
The light was fluorescent lighting (those tube lights).  I used auto white balance and I shot in Raw.   The color space (which I think is relevant to Jpeg, not to Raw) is sRGB.  I export the Raw to Adobe color space when I want to print.
The retouching is not really the problem, it's more that I have many dozens of photographs which all are improperly exposed and I have to do a correction step on all of them.   So it's the extra manual step, plus the feeling I am not getting the dynamic range out of the picture.
The correction step I do is to open 'levels' and click 'auto'; Darktable then changes the black and white references so the information in the image is using the entire possible range.  The histogram is stretched out so it reaches from end to end - but this step simply uses the color space - it can not create color-information that was not there.
Thanks for your reply, hope I managed to answer your question.
Jouko Senior Member • Posts: 1,985
As there has been mentioned, the photo is underexposed.
But as you said, the fluorecent light can also cause problems:
The color reproduction under Fluoresent tubes is usually awful. Your auto WB has done a quite good job, as the background seems to be about neutral grey. I don't use Darktable, but usually RAW converters have ability to correct wb; best way here would be to pick Wb from the background and maybe push up the saturation a bit, up to taste.
Then, correct the exposure by rising it as much as needed for midtones, and correcting the highlights and shadows as needed. Then set levels. May also need some touch for the contrast settings. Then copy the settings and paste to the shots that need similar corrections.  I use Capture 1, so that's about my workflow. The first one takes a couple of minutes, maybe less, and the copy and paste few seconds for the rest...
Those halls can be tricky places to take photos, as the tubes can have different colors - some warm, some cold, some new, some old... And they do blink, so no real continuous light. I usually set the WB manually, metering from something which should look neutral gray (or white), from the main area of action. Then I use the A-mode, letting the camera decide the shutter speed, and the lens usually wide open - usually not enough light to close down anyway. ISO as high as needed - usually high, 1600-3200, even higher. And the compensation as needed.
Check the results time to time, so you know what's coming and make some adjustments as needed. And burst modes are your friends, and the delete button for the computer too...
Cheers!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
