Which camera is your main camera?
Started 7 months ago | Polls
Erik Kaffehr
Erik Kaffehr Veteran Member • Posts: 4,096
Hi,
Would be interesting to see which systems readers have.
Please indicate the system that you are most likely to use for important work.
Best regards
Erik Kaffehr
POLL
Canon APS-C
7.6% 6  votes
Canon full frame
7.6% 6  votes
Fujifilm APS-C
13.9% 11  votes
Fujifilm 645
0.0% 0  votes
Hasselblad Digital
1.3% 1  vote
Leica APS-C
0.0% 0  votes
Leica full frame
3.8% 3  votes
Leica MFD
0.0% 0  votes
Nikon APS-C
5.1% 4  votes
Nikon full Frame
11.4% 9  votes
Olympus 4/3
13.9% 11  votes
Panasonic 4/3
10.1% 8  votes
Panasonic full frame
0.0% 0  votes
Pentax APS-C
3.8% 3  votes
Pentax full frame
1.3% 1  vote
Pentax 645
1.3% 1  vote
Sony APS-C
2.5% 2  votes
Sony full frame
11.4% 9  votes
Analogue MF
0.0% 0  votes
Analogue 24x36 mm
0.0% 0  votes
Analogue 120
0.0% 0  votes
Other make or format
5.1% 4  votes
  Show results
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 12,340
Format names
Erik Kaffehr wrote:
Hi,
Best regards
Erik Kaffehr
FWIW, any image that hasn't been cropped after capture is "full frame". This how the term was used for decades before CaNikon's marketing departments mangled it. And, FWIW, prior to digital, 35mm was referred to as "small format", as opposed to the still-unmangled terms "medium format" and "large format". The correct term for a sensor that's 24mm x 36mm is "35mm format". There's nothing "fuller" about an image from a 35mm format sensor than from any other sensor format.
As for the term "cropped sensor", well, with few exceptions, sensors aren't substantially "cropped", although some may have a few pixels around the edges that aren't included in the final readout. Some sensors are larger or smaller than others. That's it. Otherwise, any sensor smaller than the very largest sensor anywhere in the world would be referred to as "cropped", which would be unhelpful if not absurd.
I shoot several formats, all of them "small" and "cropped", including 35mm.
Words matter, and precision in their use helps.
Maybe I should change my signature to "Don Quixote".
"I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it." - George Bernard Shaw
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-GX8 Sony a7R II +49 more
Erik Kaffehr
OP Erik Kaffehr Veteran Member • Posts: 4,096
Re: Format names
Jacques Cornell wrote:
Erik Kaffehr wrote:
Hi,
Best regards
Erik Kaffehr
Hi jacques,
I essentially agree with your writing. I considered writing 24x36 mm instead of full frame.
But, it seems that 'full frame' is the pretty established name for 24x36 mm, so I decided to use that term.
Best regards
Erik
Erik Kaffehr
Website: http://echophoto.dnsalias.net
Magic uses to disappear in controlled experiments…
Gallery: http://echophoto.smugmug.com
Articles: http://echophoto.dnsalias.net/ekr/index.php/photoarticles
Jacques Cornell
Re: Format names
Erik Kaffehr wrote:
Hi,
Best regards
Erik Kaffehr
Hi jacques,
Best regards
Erik
It's not hard to write "35mm format". It's just one additional letter. It's also more readily comprehended than "24mm x 36mm" by neophytes who may not be familiar with the physical sizes of sensors and film. Pretty much everyone interested in photography knows what "35mm format" means, although that may not be the case in another decade or two as references to film fade and such terms become quaint historical artifacts.
That said, nothing about format terminology makes a lot of sense. I mean, what aspect of a 24mm x 36mm rectangle is 35mm? And "one inch" sensors aren't anywhere near 1" in any dimension. They're named after a cathode ray tube, used in old video cameras, that had a neck diameter of 1". Sheesh.
Also, what does it mean for a frame to be "full"? Is it crammed edge-to-edge with lots of subjects, perhaps a stadium full of faces? Is it the "fullest" view of a scene, maybe a wide-angle panorama or a 360-degree image? And, if you're using "full" to mean "entire" or "complete", well, that applies to any uncropped capture.
The idea that any format is the "full" one bothers me because 1) it's nonsensical, and 2) it represents the unconscious popular acceptance of bias self-servingly peddled by marketers.
AlbertTheLazy
AlbertTheLazy Veteran Member • Posts: 8,238
Re: Format names
Still, the idea that any format is the "full" one bothers me because 1) it's nonsensical, and 2) it represents the unconscious popular acceptance of bias self-servingly peddled by marketers.
Come back 'Full plate', all is forgiven!
http://camera-wiki.org/wiki/Plate_sizes
Albert the lazy photographer
Having fun with my cameras in Scotland
 AlbertTheLazy's gear list:AlbertTheLazy's gear list
Canon PowerShot G15 Fujifilm X-T1 Sigma 70-300mm F4-5.6 APO DG Macro Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Jacques Cornell
Re: Format names
Perhaps 6½ × 8½ were the largest glass photosensitive plates ever made. I notice the larger formats listed are all sheet film.
I'm pretty sure 35mm sensors are not the largest imaging sensors ever made.
rurikw
rurikw Veteran Member • Posts: 3,012
Re: Which camera is your main camera?
I ticked Panasonic 4/3 because I assumed you actually meant m4/3.
 rurikw's gear list:rurikw's gear list
Sony Cyber-shot DSC-R1 Nikon Coolpix 5000 Sigma DP3 Merrill Sigma DP1 Merrill Sigma DP2 Merrill +28 more
Erik Kaffehr
Yes,
m4/3 is a variant of the 4/3 format, intended for mirrorless cameras.
The reason I used the term 4/3 was to allow for both m4/3 and 4/3, but above all to separate from Panasonic's 24x36 mm format.
https://en.wikipedia.org/wiki/Four_Thirds_system
https://en.wikipedia.org/wiki/Micro_Four_Thirds_system
Best regards
Erik
Erik Kaffehr
KCook
KCook Forum Pro • Posts: 17,780
This appears to assume we are all professionals???  The system I have and use most is M4/3.  So that got my vote.  However, "important work" implies a client.  I am a hobby guy, for a fat check I would not use my M4/3 hobby camera.
Kelly
 KCook's gear list:KCook's gear list
Canon EOS 50D Olympus PEN E-P5 Panasonic G85
Erik Kaffehr
Kelly
Hi,
I don't think it implies doing paid work.
Just as an instance, let's say that I do travel and want to have good images. That case I would consider that important. Because I may not get to that place another day in the same weather.
The polls here don't allow for multiple choices. The writing is just intended as a guideline what gear to mention when there are different option.
In my case, my total earnings from photography probably sum up to 20$ in 50 years,
But I have Sony APS-C, Sony 24x36 mm, Hasselblad with a digital back.
If I go some place where I want good pictures, I would certainly take the Sony 24x36 mm.
This shot to me a three hour walk, back and forth, I used the Sony A7rII with a Canon zoom lens.
This one was shot next morning, just 30 m from my RV, this time I used the Hasselblad with my P45 back.
Best regard
Erik
Erik Kaffehr
KCook
Kelly
Hi,
Best regard
Erik
To fit that example I would have to say I never do important work!
Kelly
jrtrent Veteran Member • Posts: 5,797
other, Samsung APS-C
Though lately, I find myself often turning to a Sigma 1.7X crop sensor compact camera, instead; at people gatherings, the smaller and less aggressively styled compact seems to help others feel more at ease than when using the DSLR.
evetsf Senior Member • Posts: 1,353
Re: other, Samsung APS-C
+1
I have two Panasonic m43 bodies: DSLR-style G9 & rangefinder-style GX9. The GX comes out to play at those times when one does not want to be the conspicuous photographer. With the Pana 20mm f/1.7 pancake lens it looks "harmless" but takes great photos.
Steve
 evetsf's gear list:evetsf's gear list
Fujifilm X-S1 Panasonic FZ2500 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Leica DG 50-200mm F2.8-4 +3 more
Erik Kaffehr
Thanks for doing the poll!
Hi,
Thanks for responding. But we need more answers to get any picture of what folks use!
I have noted that a significant number of responders use systems that were not listed. Sorry I missed!
What systems are used?
Best regards
Erik
Erik Kaffehr
Re: Thanks for doing the poll!
Erik Kaffehr wrote:
Hi,
Probably a lot more people would see the poll if it were moved to the Open Talk forum.  I don't see a moderator listed for this forum, but you might try the feedback link to see if someone could move it.
MikeyBugs95
MikeyBugs95 Regular Member • Posts: 421
Well at least I know I'm not alone in using Pentax in this poll...
It's a pretty simple task of 3D modeling something. It's getting it to fit that takes most of the time!
 MikeyBugs95's gear list:MikeyBugs95's gear list
Pentax K-3 II Sigma 50-500mm F4.5-6.3 DG OS HSM Tamron SP AF 90mm F/2.8 Di Macro Pentax smc DA 35mm F2.8 Macro Limited Sigma 28mm F1.8 EX DG Aspherical Macro +12 more
pocoloco Senior Member • Posts: 2,874
Got an OMD EM1 M1 and two OMD EM5 M2 cameras. Isn't a main camera between these three. The lens that is on them determines which one I use
Still got a Panasonic GX7 but I am bout to sell it (if anyone is willing to exchange some money for it )
 pocoloco's gear list:pocoloco's gear list
Olympus Tough TG-2 Sony RX100 Olympus E-M1 Olympus E-M5 II Olympus 12-40mm F2.8 Pro +15 more
