Color space for Benq pd3200u in photoshop
Started Dec 2, 2019 | Discussions
VasilisT New Member • Posts: 24
Hello pip
I just bought a Benq Pd3200U. I am going to calibrate it with an Xrite diplay pro.
I am into web based photography. If I am right sRGB is the go to color space to work with in photoshop, isn't it?
Should I calibrate my monitor in sRGB color space or aRGB?
This monintor has an100% srgb and 73% aRGB so I can assume that sRGB is the way to go.
Some feedback will be appreciated and excuse my English
Ken60 Senior Member • Posts: 2,710
Re: Color space for Benq pd3200u in photoshop
Same image one is sRGB the other ARGB, which looks better posted here to you ?
Gear ... what I need to get the job done , after all you don't see mechanics listing their brand of spanner as a qualification .
OP VasilisT New Member • Posts: 24
I would say identical
So . the question .... what monitor profile are you working with ?
If you set it to a wider gamut , will you notice a difference then ?
But I dont have a wider gamut. sRGB is the 100% gamut on this monitor.
Let me get it right cause I am confused.
1. I havea monitor that is capable of 100% sRGB and 73% aRGB.
2. So as long as I am into publishing for screens/mobile etc. and with a monitor capable of 100% sRGB I am good to go.
3. I should calibrate it (which i haven't done yet) based on sRGB gamut and I should edit in Photoshop with the working space set in sRGB, isn't it?
If thats all you need, then go for it !
