G9 PAL/NTSC, frame rates
Started Dec 1, 2019 | Discussions
hindesite Veteran Member • Posts: 4,893
I understand the G9 still has the stupid PAL/NTSC regional restrictions which the GH5 does not (you can switch between PAL and NTSC on the GH5, but not the G9).
However, in a strange twist, it appears on examination of the specs that while NTSC versions have (for example) 4K at 30p and 60p, the PAL versions actually have more choice, adding 25p and 50p without removing 30p and 60p as they have done on previous cameras like the G7.
Can any owners of the G9, especially PAL ones, confirm this?
Panasonic GH5 Panasonic Lumix DC-G9 Panasonic Lumix DMC-G7
paul cool
paul cool Veteran Member • Posts: 3,137
Re: G9 PAL/NTSC, frame rates
going through menu ,MOV 4k 8bit ,150m,60p,4K ,10 Bit,30p 150m,4k 8 bit 100m 30p,MP4 Hvec 4k 72m 30p, internal recording more options if external recording
 paul cool's gear list:paul cool's gear list
Sony a7R III Sony a1 Sony FE 70-200mm F2.8 GM OSS Tamron 28-75mm F2.8 III Tamron 17-28mm F2.8 Di III RXD +3 more
yslee1 Contributing Member • Posts: 640
Yes, that is the case with mine. I have 60, 50, 30, 25 and 24 fps options. PAL unit, bought in Singapore.
OP hindesite Veteran Member • Posts: 4,893
Thanks, appreciated. For once, the PAL version is better than the NTSC version, most unexpected.
