image resize/ resampling
Started Nov 30, 2019 | Discussions
JS photo
JS photo New Member • Posts: 23
Hello,
I've been having a few issues with my images actually being a little too sharp. I shoot a lot of weddings and it's not the best look when you can see every pore on a brides face.
With my D750 I never had any issues with this. After I was done editing in Lightroom I would batch portraiture on all images with photoshop, making everyones skin look quite pleasant.
With my D850, which I'm realizing that I really do not enjoy shooting weddings with( I can't wait for the d760 or d770 or whatever they'll call it). There is simply too much detail in their skin and it looks bad even after I add portraiture. I realize that I can take down the clarity and sharpness in post..but I was wondering about image resizing or resampling. I don't understand how this works but I've been told that it would help me get the same look that I used to get with the d750 in terms of skin smoothness...the reason I think at least is because I would be using not as many megapixels which would mean not as much detail etc. less pores etc.
Would it help to use the MEDIUM raw vs LARGE raw as well?
If anyone has any advice for me I would greatly appreciate it! Please explain it in a way that you would to someone who knows nothing about resizing/resampling.
Thanks!
Jeff
 JS photo's gear list:JS photo's gear list
Nikon D850 Nikon D780 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A +2 more
Nikon D750 Nikon D850
RDKirk Forum Pro • Posts: 16,162
Re: image resize/ resampling
JS photo wrote:
Hello,
Thanks!
Jeff
Work with Portraiture more.  It can do what you want. Then you can assign that setting as an Action and perform it on images with a keystroke.
That will be much easier than messing with resizing or resampling, which are activities best done for the purposed they're designed for.
RDKirk
'TANSTAAFL: The only unbreakable rule in photography.'
 RDKirk's gear list:RDKirk's gear list
Canon EOS 5D Mark II Canon EOS 70D Canon EOS 5DS R Canon EOS 80D Canon EF 24mm f/2.8 +7 more
JS photo
OP JS photo New Member • Posts: 23
Thanks! I'll mess around with portraiture more until I get it right.
Cheers!
rumple
rumple Senior Member • Posts: 1,805
You could try Mraw.  It has slightly less acuity than the regular (large) size.  Also greater dynamic range and smaller file size, both benefits at events.
"THINK" - Watson
Photomonkey Senior Member • Posts: 2,823
What size are you delivering? Are you making prints?
The latest version of LR CC Classic permits multiple outputs on export.
Are you doing any sharpening in post? I see a lot of people adding sharpening to images as a matter of course whether or not they need to.
If the images look too sharp I agree with the others to reduce apparent sharpness via Portraiture or through Clarity in LR. If the images are too sharp for you at maximum res they will still be disagreeable to you at smaller sizes.
 Photomonkey's gear list:Photomonkey's gear list
Kodak Pixpro S-1
