New GH9, New firmware update......and I'm confused!
Started Nov 29, 2019 | Discussions
3pinner Regular Member • Posts: 120
Yep, BRAND new G9. Fingerprints on it aren't even dry yet. Took it out for a test run, then installed the new firmware update 2.0
I've been going through all of the menu items on the camera, and setting up for my preference so far. I have a G7, so a lot of it was familiar, but of course there's a lot of new great stuff.
I'm confused because:  The firmware update was successful, in Version, it states it as 2.0 (was 1.3 before); but as I look through the menu, I don't see the new items that should be there. (near shutter, far shutter etc).
But I do see one item that is new: Activate
It's in the Function Menu>Activate, and the options are: Export Serial Code, Import Activation Code, and in a greyed-out option: Activation List.
What the heck is  this??
Sorry about such a Noob question here on this distinguished forum. Please feel free to laugh and point before answering my question, and I really appreciate your help!
I will be asking others as I really dig into the system. Might even post some pics later for your input. Always looking for improvement!
Bruce
Panasonic Lumix DC-G9 Panasonic Lumix DMC-G7
northlondon43
northlondon43 Senior Member • Posts: 1,941
Re: New GH9, New firmware update......and I'm confused!
Bruce
Hi Bruce. A new camera plus a new firmware to learn = aarrgghh. I get it.
However, you might find it useful to download the latest user guide /manual which includes the V2.0 changes 😊
Adrian
An amateur, atheist, alliterationist
 northlondon43's gear list:northlondon43's gear list
Fujifilm X100V Panasonic Lumix DC-G9 Panasonic Lumix G 25mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +4 more
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
Paid V-Log update. You're probably not needing that right now.
Jeff
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
OP 3pinner Regular Member • Posts: 120
You are indeed correct!
I'll get that later.
AND for others that may be scratching their heads, I finally found the updated user manual on the Panasonic web site. (they did a REALLY good job of hiding it)
https://av.jpn.support.panasonic.com/support/dsc/oi/index.html?model=DC-G9&dest=EG
The explanation is in there.
Thanks for the replies, now off to burn through battery #1 to learn this thing!
iano Senior Member • Posts: 1,896
The link is provided in the menus (spanner - page 1 - 'online manual' then 'url display') and this will give the correct 'dest' value for the camera.  Mine uses 'dest=GN' in place of 'EG' not sure what is different in the manual
 iano's gear list:iano's gear list
Panasonic GX850 Panasonic Lumix DC-G9 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Leica D Summilux Asph 25mm F1.4 +9 more
