Olympus E-P5 with Metz 15 MS-1 'Ring' Flash?
Started Nov 29, 2019 | Questions
Jim Ford Senior Member • Posts: 1,240
I'm having problems setting up my Metz ring flash with my Olympus E-P5.
I find that the settings for RC flash on the camera rather opaque.
Can anyone share their settings with me, please
Jim
Olympus PEN E-P5
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Olympus E-P5 with Metz 15 MS-1 'Ring' Flash?
Maybe some help on my E-P5 menus page http://homepages.ihug.com.au/~parsog/olyepl1/56-ep5-custom-menus.html#rcmenu
Hope that is of some help. Sorry I didn't see this post earlier.
Regards...... Guy
glassoholic
glassoholic Veteran Member • Posts: 7,641
The Metz must also be in the mode for Oly compatibility.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Jim
According to this compatibility list there should be no problems. The E-P5 supports TTL master.
https://www.intro2020.co.uk/EmbeddedContent/Brands/Metz/Downloads/metz_compatibility_aug16.pdf
If you bought the MS1 a while ago, it may be a good idea to first update it's firmware, see page 85 of the manual.
How are you trying to trigger the MS1, as slave to a primary Olympus flash, or with a cable? I use it as slave to the little FL-LM3 flash that came with the EM5.2 and Pen-F, and it just works fine.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
Guy Parsons
Jim
With RC control the E-P5 pop-up flash set to RC signals only at low power should work fine.
OP Jim Ford Senior Member • Posts: 1,240
It turned out that I had V1.0 of the firmware, which doesn't support the E-P5. I updated the firmware and it's now OK (but it took an hour to find the USB port - until I took the lens adaptor off!).
Thanks to all for the replies.
Jim
glassoholic
Jim
Good to hear... I have a Metz 64 AF2 that needed a FW update to work remotely with an EM1.2 after the EM1.2 had a FW update!
Addicted To Glass
