Best long macro for X? Cost *is* an object!
Started Nov 26, 2019 | Questions
CeeDave
CeeDave Senior Member • Posts: 2,208
Hello,
I am doing more macro shooting, but find my 60 doesn’t have enough reach for many situations (bugs, mostly), and the magnification on my 90 and Rokinon 135/2 are not quite high enough. The 80 doesn’t give enough reach and is a bit more than I want to spend anyhow. I reckon my two options are:
  1. Adapt a 100 to 200 mm macro from another manufacturer. If I did this, I’d want aperture controlled properly, so either something like a Nikon AI or D (I have a dumb D adapter [Nikon 200/4?] and a dumb M42 [Takumar 100/4?]) or perhaps invest in in a smart adapter (like Fringer [which Canon?]; not cheap!). Any adapted lenses that you’d recommend?
  2. Get an achromatic diopter that’d cover both the 135 and 90 (77 mm). These cost about $150 and up. I’m thinking maybe 2 of them, like a +2 or +3 first, maybe followed by a +4 or +5. I’d also like to try the Fujifilm teleconverter(s) with the Rokinon 135, I may just rent one first. Comments?
Thanks for any experience or suggestions you can share.
Chris
A couple of Fuji cameras and assorted X-mount and adapted primes
 CeeDave's gear list:CeeDave's gear list
Fujifilm X-E2 Fujifilm X-H1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +12 more
biza43 Forum Pro • Posts: 15,074
Re: Best long macro for X? Cost *is* an object!
From my experience, I would go with your option #1. Adapted lens.
I have used your option #2 with an old but excellent Canon Close up Diopter (250D), but such a "filter" is usually more user friendly with a zoom.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Quindere Forum Member • Posts: 89
I suggest you to give a try to NIKKOR AF Micro 105mm f/2.8D.
CeeDave
OP CeeDave Senior Member • Posts: 2,208
That is definitely worth looking at, although at the short end of the range I think I want.
Thanks!
Chris
Craig268
Craig268 Senior Member • Posts: 2,005
Extension tubes? It's very old school but they work great and very inexpensive.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
pauldb126 Regular Member • Posts: 215
What do you mean by 'long'? Working distance or magnification?
A cheap option that I have used is either of the Raynox on the Fuji 50-230 - can give a variety of magnifications and decent working distance.
Another left field suggestion is to put an extension tube in front of a 1.4× or 2× teleconverter. The glass of the TC did inside the tube, so you don't need to rely on the quoted 'compatibility' of the lens with the TC.
-Paul
 pauldb126's gear list:pauldb126's gear list
Fujifilm X-T3
CeeDave
Thanks for the suggestion, but extension tubes don’t help much at longer focal lengths (effect proportional to 1/F).
Chris
getochkn
getochkn Senior Member • Posts: 1,109
I have this lens, 60mm 2:1 manual focus lens in Canon mount that use on my Fuji with a cheap ef->x adapter. Since the lens is manual focus, a $20 adapter works fine.
Oshiro 60mm f/2.8 2:1 LD UNC Ultra-Macro Lens for Nikon D4S, DF, D4, D3X, D810, D800, D750, D610, D600, D7200, D7100, D5500, D5300, D5200, D5100, D3300, D3200 and D3100 Digital SLR Cameras https://www.amazon.ca/dp/B010R8MGA6/ref=cm_sw_r_cp_apa_i_NDV3Db6EH2MWC
 getochkn's gear list:getochkn's gear list
Panasonic Lumix DMC-LX3 Canon PowerShot ELPH 360 HS Fujifilm X-T1 Fujifilm X-T30 Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
CeeDave
-Paul
Sorry, I should have been clearer. I’d like to have mags of around ½ or better with at least a few inches (~10 cm) of working distance (lens to subject). So, focal lengths of 90 mm or more, I think.
Chris
CeeDave
Thank you for replying, but I already have a 60 and the working distance is to short for some of my attempted images.
Chris
CeeDave
Thanks for your reply. My current first choice for adapted is the Takumar 100. Any comments?
Chris
CeeDave
I am looking for those. The G version is easy to find, the D and older a bit rarer (in good condition). Thanks.
Chris
See the two references I posted from the Pentax forum.... They will tell you the working distance you'll get with different powers of close up lens.
There is a separate calculation using the power of the close up lens combined with focal length of your main lens that gives you the magnification.
Fujifilm X-T3
baobob
baobob Forum Pro • Posts: 18,248
I use an old Tamron Macro 90mm f2.5 that can be found on ebay i payed for mine 100$
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
baobob
Other cheap solution could be to fit on your 90mm different bonnettes to allow to go closer I use my 55-200mm that way with a Raynox 150 which happily does not creat any vignette in all FL from 55 to 200mm transforming the 55-200mm in a kind of a swiss knife for macro...
CeeDave
Thanks, I’ll give it a look.
Chris
CeeDave
Interesting idea. I have been considering a used 55-200, and with a good achromatic diopter it night pull double duty.
Chris
baobob
I am very pleased with the Raynox
GossCTP Veteran Member • Posts: 6,207
I have an old raynox that I haven't used in a while. Any chance it works as well on the 50-230?
"Law and order" is anathema to liberty and justice.
 GossCTP's gear list:GossCTP's gear list
Panasonic Lumix DMC-LX5 Pentax K20D Pentax K-5 II Fujifilm X-H1 Pentax smc FA 50mm F1.4 +8 more
getochkn
