D500 Exposure and AF won't display on top
BeaverGrad Junior Member • Posts: 38
The first picture is my sister-in-law's D500 top LCD, the second one is mine. The exposure  +/- indicator and AF is not visible on hers. Is this a setting that I can't seem to find? Is there another reason? Any help would be appreciated.
 BeaverGrad's gear list:BeaverGrad's gear list
Nikon D500 Nikon Z6 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S 70-200mm F2.8E FL ED VR Nikon AP-F 70-300mm F4.5-5.6E +3 more
Nikon D500
DaveMC Regular Member • Posts: 202
Re: D500 Exposure and AF won't display on top
I believe your sister-in-law's camera could have the camera AF/M focus switch turned to the "M" position which explain the auto focus mode indicator but not the absent exposure compensation indicator.
 DaveMC's gear list:DaveMC's gear list
Nikon D500 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 70-200mm F4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +6 more
Bill Ferris
Bill Ferris Veteran Member • Posts: 5,442
Good call on the lens being set to manual (M) focus. That would explain it.
The in-camera meter (along with f-stop, shutter speed and ISO) displays on my top LCD for only a brief time after turning the camera ON, turning on the light or half-depressing the shutter release. After about 10 seconds those displays go away. It's similar to the behavior of the same displays in the viewfinder.
Bill Ferris Photography
Flagstaff, AZ
http://www.billferris.photoshelter.com
 Bill Ferris's gear list:Bill Ferris's gear list
Nikon D610 Fujifilm X-T20 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Tamron SP 24-70mm F2.8 Di VC USD +3 more
OP BeaverGrad Junior Member • Posts: 38
I thought that was it too but she just sent me a pic of the AF/M switch. It's in AF. I wonder if it's the Tamron lens she's using. 70-200 G2
Tamron 70-200 f/2.8 G2. Its switch is in the AF position.
Bill Ferris
FWIW, I have the gen 1 Tammy 70-200 f/2.8 Di VC USD and, when mounted to my D500, the autofocus mode displays on the top LCD. With the Tamron mounted to D610 and D90 bodies, the AF mode also displays on the top LCDs.
Flagstaff, AZ
Hmmmm….some other ideas (but this is now brainstorming);
in the following order
Check firmware is up to date.
Try another lens
Perform a reset to default settings, see page 230 of the manual.
If that doesn't fix it (assuming this is with another lens), and short of any other ideas forthcoming, then it may need to be sent to Nikon.
Chuvarsky
Chuvarsky Senior Member • Posts: 2,143
Not the lens, tried it on my camera, display looks like yours.
Dick
 Chuvarsky's gear list:Chuvarsky's gear list
Tamron SP 150-600mm F5-6.3 Di VC USD G2 Nikon D500 Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED Tamron 15-30mm F2.8 +7 more
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,123
As previously asked, is the focus mode selector on the front of the camera set to AF? You need to briefly half press the shutter button to update the control panel after changing focus mode.
In manual mode, the exposure compensation display represents the relative under or over exposure at the current settings. It is only shown when metering is active. In other modes, the exposure compensation is also only shown when metering is active. However, a +/- indicator is always displayed when when any offset is applied.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Panasonic Lumix DMC-FZ200 Olympus Tough TG-3 Fujifilm X30 Canon EOS 5D Mark III +21 more
Jimusny
Jimusny Senior Member • Posts: 2,049
is your set to auto ISO? I dont think exposure compensation shows in full manual ISO
 Jimusny's gear list:Jimusny's gear list
Nikon D500 Nikon AF-S Teleconverter TC-14E II Nikkor AF-S 300mm f/4E PF ED VR Nikon 500mm F5.6E PF Olympus E-M1 +9 more
