Re: Are these horizontal lines normal from R cameras?
I think it is clear, just by deductive reasoning that there are four factors that could be involved here: 1) Demosaicing of software, 2) type of shutter, 3) shutter speed, and more general electrical interference.
I think I noticed that on all of the shots used as examples of this phenomena, I noticed that the shutter speeds were very high - 1/10,000, 1/5,000 and the slowest was 1/800. I wonder if, at slower speeds, this may not occur, which would indicate some sort of timing issue or even electronic interference having to do with the shutter, especially with the electronic shutter, but even with the mechanical one as well. Likewise, and possibly related, a sort of generally sourced electrical interference, caused by so much current running through so many working circuits and boards and such packed into such a small and confined space may have limited the ability of Canon to shield some components from electrical interference that may only show up as in the examples shown here.
If it's just a problem of demosaicing in software, Canon needs to work on DPP and work with Adobe and others, and maybe work on CR3 itself, in order to correct this, although since these examples seems to be shown at file magnifications greater than 100%, this issue isn't exactly paramount and may even be somehow related to display issues, as opposed to problems intrinsic with the files themselves, although I find that the least likely possibility. The other possible causes may be harder to correct, as they may be related to the physical design of the camera.
For the record, I have an EOS R that I've heavily used for quite some time, and have never seen anything like the results on this thread, although, if it makes any difference, I now have no lenses that are faster than f/2.0. Again, this is not directly related in any way, but is similar: just yesterday I shot a couple of thousand shots of people sitting in front of huge LCD panels (don't know if backlight is from fluorescent or LED) being simulcast on video and had to use the electronic shutter for "silence." Wow, on those panels, what banding! Tried every shutter speed from 1/120 down to 1/15 to try to tame the panel banding. Had to give up at 1/20 as the lowest possible shutter speed at which I could hope to capture people without every frame being a blur, and even then, the horizontal banding was bad. Interesting enough, the pro LED lighting on the people themselves was fine, with no banding or other artifact, even at 1/120 of a second. That was amazing.
By the way, I saw issues just like this way back in the early 2000's with some $30,000.00 digital backs, when viewing files at greater than 100%.
Keep learning; share knowledge; think seriously about outcomes; seek wisdom.
