a Question of MP Size - MFT
Started Nov 22, 2019 | Discussions
Fulcanelli
Fulcanelli Contributing Member • Posts: 566
I'm considering a back-up camera to my Panasonic G9...
My first (and only) choice would be a GX9, if I don't get a second G9.  When reviewing the GX9, I read comparisons to the GX85 (I have one) and the discussion started that the GX9 is really an updated GX85, not updated GX8.  I had a GX7 and it was a fantastic camera (and I wasn't as pleased with the GX8.)
Anyway...the GX85 has a 16 MP sensor, the GX9 a 20 MP sensor.  A number of reviewers suggested that unless video is a selling point (not for me), the GX85 might be a better choice.
So...there is more to the sensor than size...?
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Re: a Question of MP Size - MFT
most of the time you only need less than 8 mp, but If you crop alot you may want 20 mp.
Since I don't know your final output, I could not be fully certain with any answer.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Felice62 Veteran Member • Posts: 5,079
At today's price grab a second G9. There is a lot of content for the buck in that camera..
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
larsbc Forum Pro • Posts: 18,282
The GX9 has a tilting EVF and a dedicated AF/MF switch like your GX7 does and the GX85 does not.
You can also read this article that does a good job of comparing the two:
https://mirrorlesscomparison.com/panasonic-vs-panasonic/gx9-vs-gx85-gx80/
Tomx72 Senior Member • Posts: 1,574
Not all mft, not even all 20MP MFT sensors are made the same. The sensor of the E-m1ii and e-m5iii are a step forward (around 1/2EV better) compared to the previous 16/20MP sensors, which were about the same.
 Tomx72's gear list:Tomx72's gear list
Panasonic Lumix DMC-GX85 Nikon Z6 Olympus 12-40mm F2.8 Pro Sigma 150-600mm F5-6.3 DG OS HSM | S Olympus 40-150mm F2.8 Pro +4 more
Fulcanelli
OP Fulcanelli Contributing Member • Posts: 566
You must be reading my mind.  I've been thinking on this quite a bit and am about ready to pounce.  I do like variety and having two similar but different cameras is an appealing feature.  I am very fond of smaller gear, too.
But then the G9 is quite good for sure.  I have a GX85 but I really don't like the camera at all.  I will be retiring it from active duty.   Since the GX9 isn't really the next gen of the GX8, the G9 does make sense...and good pictures, too.
Fulcanelli
I think I need to read up on camera sensors.  Thanks.
