olympus pen external shutter signal
Started Nov 18, 2019 | Discussions
cvhmanchester New Member • Posts: 17
I have an E-P5 for which I want to computer control the shutter (for stacking).  What electric signal should the computer send through the USB plug?
Is it just a making a connection between a couple of pins?
Thank you
 cvhmanchester's gear list:cvhmanchester's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +3 more
Olympus PEN E-P5
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: olympus pen external shutter signal
Thank you
I googled and found some old info that should be OK to use, the pin numbers and a simple switch arrangement in this case. So it is a matter of making a connection between pins.
https://www.instructables.com/id/Olympus-Evolt-E-510-Remote-Cable-Release/
https://www.instructables.com/id/Olympus-Evolt-E510-Remote-Cable-Release-Version-2/
Between those two pages you should get a good idea of how to make it work.
Regards..... Guy
