X-E3 Ergonomics
Started Nov 17, 2019 | Questions
okmarzo Regular Member • Posts: 200
X-E3 Ergonomics
I've shot with an X-T20 before and it felt too small without an additional hand grip. I just couldn't really get a good handle on it. If I were to shoot with an X-E3 would I have the same issue? I understand the X-E3 is even smaller but I was wondering if somehow the ergonomics is more "balanced" so it could possibly feel better in my hands?
My hands are on the the smaller/medium size. I have an X-T2 and I can shoot perfectly fine without a grip. So I'm wondering about the X-E3 to go even more compact.
 okmarzo's gear list:okmarzo's gear list
Fujifilm X100V Fujifilm X-Pro3 Sony a7R IVA
Fujifilm X-E3 Fujifilm X-T2 Fujifilm X-T20
Erik Baumgartner Senior Member • Posts: 6,893
Re: X-E3 Ergonomics
I don’t own an X-E3, but I’ve used one. Because of the offset EVF the handling is different than the X-T20, and if you are left eye dominant your face might be a bit less squished, but having large hands, the X-E3 still feels too small without an additional handgrip - and the lack of a d-pad is a dealbreaker for me anyway. You should really try to get a hold of one yourself, these things can be very subjective. Personally, I think most of the Fujis  greatly benefit from a handgrip, including the X-T2  ( I highly recommend the Meike). I like my X-T20 with a grip, still very small and light, but the handling is better by several orders of magnitude.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
AndyH44
AndyH44 Veteran Member • Posts: 3,106
Re: X-E3 Ergonomics
With the lighter lenses, i.e. XF27 f2.8, or XC lenses, it doesn't need a grip.  But I found that the MetroCase grip is just about perfect for best control and ergos, and it only weighs 1.5 oz.
"The world doesn't exist to satisfy our expectations."
OP okmarzo Regular Member • Posts: 200
Re: X-E3 Ergonomics
Yeah I figured it’s too small. Can you use the joystick to navigate through the menu or do you have to use the lcd touchscreen?
Birdmanfriday Regular Member • Posts: 441
Re: X-E3 Ergonomics
I use mine with a leather half case and find it very comfortable to hold with small primes - the handling is excellent. I’m sure it would be fine with lenses up to the size of the 18-55. With bigger lenses you really just hold the lens instead of the camera using your left hand to take most of the weight.
I use mine with the touch function switched off and the navigation via the little rocker button is fine. To me it’s just fine and I’m an XT user too. The design is best suited to to right eye use.
 Birdmanfriday's gear list:Birdmanfriday's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
Helen
Helen Veteran Member • Posts: 7,606
Re: X-E3 Ergonomics
You use the joystick and the still-existing OK button.  The menu doesn't respond to the touchscreen, unfortunately.
Re: X-E3 Ergonomics
You can use the joystick for the menus, but you're stuck with the touchscreen for custom functions, which, if you're left eye dominant and have a nose on your face, is mostly worthless.
RivkiLocker
RivkiLocker Senior Member • Posts: 1,565
Re: X-E3 Ergonomics
I owned the XE3 and sold it some time back to fund some other camera purchases. Recently I got the XT30. I would say they are very similar in terms of size. They are a bit differently constructed, so you might find one more comfortable than the other. For me, the XT30 has the edge - the layout and ergonomics just work better for my style shooting, size of my nose, whatever.
But in terms of the size, they are very very similar. Both are quite puny. I added a meike grip to both which helped some. I do have small hands so like the small size personally.
 RivkiLocker's gear list:RivkiLocker's gear list
Leica Q2 Leica M Typ 240 Fujifilm X-H1 Leica SL2-S Fujifilm XF 35mm F1.4 R +6 more
KariP
KariP Veteran Member • Posts: 6,458
Re: X-E3 Ergonomics - i have big hands ...
I have also an older  X-T1   and it feels a bit better with the grip it has. BUT - X-E3 is quite nice in real use.  With a lens like 18-55 OIS  it is very balanced. And my fingers are not short...
The lcd is touch sensitive and  Q menu can be used quite easily . The "swipe" movement to use some functions is a bit strange when you use it the first time.
Quality / price is also quite balanced IMO
Kari
I started SLR photography in 1968, first DSLR was Canon 40D in 2007. Now Fujifilm X-E3 is my favourite traveling camera - also NEW! 5DMkIV for landscapes, BIF/nature .
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +13 more
maltmoose Veteran Member • Posts: 3,049
Re: X-E3 Ergonomics
I owned and used the xt20 for over a year and then tried the xe3 and got that as it feels less cramped and the joystick is great. Sold the xt20.
I also tried a grip on the xt20, didnt fix the issue for me. ( i still have the xt20 grip in a draw for some reason..)
The xe3 really is better ergonomically as you have more space and feels more comfortable to me. no dpad isnt an issue for me.
Main issue is the lack of tilt screen...otherwise its an improvement over xt20 imo if your ok with EVF on top left corner.
I could be wont be getting an xt30, i do want and xe4 with tilt screen and better eye point though.
Try before you buy, as we are all different.
