Oly 60 mm and MC-14
Started Nov 17, 2019 | Questions
bikerguy Regular Member • Posts: 304
Oly 60 mm and MC-14
Has anyone used the Oly 60 mm macro with an extension tube and the MC-14? If so, what were the results?
Bikerguy
 bikerguy's gear list:bikerguy's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 14-150 F4-5.6 II +1 more
epozar
epozar Senior Member • Posts: 1,969
Re: Oly 60 mm and MC-14
https://www.dpreview.com/forums/post/63115701
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
MacroLunchtimes
MacroLunchtimes Regular Member • Posts: 283
oneofone25
Check out his sand grain images first decent true macro images.
Here is mine..salt and peppercorn
 MacroLunchtimes's gear list:MacroLunchtimes's gear list
Olympus E-M1 III Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +1 more
MacroLunchtimes
You will need to get the right extension tube as the 60mm and 1.4xtc wont go together otherwise.
epozar
Why don't you simply use more extension tubes for more magnification?
oneofone25
oneofone25 Senior Member • Posts: 1,586
More than 42mm of extension tubes and your connection with the 60mm macro lens is messed up.  Even with tubes, you are losing a significant amount of light.  You lose less light with the MC-14
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
(unknown member) Veteran Member • Posts: 7,274
You lose same amount of light with same magnification ratio. Inverse square law. More you magnify, more you lose. The difference is that you set a extra glass with teleconverter that has reflective surfaces, compared to just air.
The only change is when you use frontal teleconverter as those has wider area to capture more light before it goes through lens itself.
Why example 2.0x teleconverter that goes between body and lens loses 2 stops of light, but 2x teleconverter you screw front of the lens doesn't lose any. But you exchange extra size and weight for that.
MacroLunchtimes
I only use the 16mm ext tube in real life situations, was just putting them both on to show what can be achieved.
Yes light will be reduced but you are not using this handheld in "normal" light conditions.
This is typically used in studio type conditions with flash systems or lighting rigs.
