Lee filter compatibility with NiSi holders
rvk82 New Member • Posts: 5
Hope I am posting this question in the correct forum: Can I use Lee 150x150mm filters with the NiSi 150mm holder? Would like to know if the filter will properly fit in the holder without the risk of falling to the ground and if there will be any light leak.
I have the S5 and Q holders from NiSi and both of them accept 2mm thick filters.
BrokenPhotography
BrokenPhotography Regular Member • Posts: 434
Re: Lee filter compatibility with NiSi holders
According to NiSi's site, either 150mm x 150mm (Square) or the 150mm x 170mm (Rectangle) filters can be used with this setup. Just make sure you have the correct mounting system for your camera & lens as each of these are mount specific.
akustykmagmanetpl Senior Member • Posts: 1,187
I can only confirmt that Nisi 100mm holders are neatly compatible with Lee 100 filters.
 akustykmagmanetpl's gear list:akustykmagmanetpl's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM Canon EF 135mm F2L USM +9 more
