Some IR with the M5 - Oregon/Wallula Gap
HaroldC3
HaroldC3 Senior Member • Posts: 2,509
13
I recently upgraded my IR camera by purchasing a used M5 and sent it in to get converted to IR (decided on 720nm). My end goal with IR is B&W so I opted not to go for a lower wavelength.
Anyways, I've been shooting with the camera for a while now and really think it does a good job (pretty decent upgrade over my original M IR camera). Processing the 720nm files is a bit different than the 665nm that I was used to but I'm coming along.
I continue to use the 15-45mm as my walk-around lens. I wish I could use the 18-55mm but it has a bad hotspot so I am stuck with the 15-45mm. Thankfully, the 11-22mm does not exhibit a hotspot so I at least have that lens available.
Today, I took a drive to Hat Rock State Park in Oregon. It had been foggy all morning where I lived and I was hoping the fog would break by the time I go to the park. Lucky for me, the fog parted about 2 miles away from the park and I had mostly clear skies.
So I walked around the park and fired off a few images. Nothing spectacular but it's always nice to try and challenge myself to find compositions. Here's a few shots I took.
Hat Rock
You can read some history about the area here: http://www.columbiariverimages.com/Regions/Places/hat_rock.html
So after I was done here I headed back to the fog. It was noon at this point and still really foggy. I contemplated going on a hike and ultimately decided to stop and do it. The hike is located in the Wallula Gap near the southeast border of Washington and Oregon. You can read about the history of the Wallula Gap here: http://columbiariverimages.com/Regions/Places/wallula_gap.html
Overall the hike went pretty well. Even though it was completely foggy I had fun exploring. I saw hibernating balsam root all over, so I'm anxious to see what it looks like in the spring. I did take a few images in the fog but I think for the most part, my images lacked a subject so most were uninteresting. But a few I took during the hike are below.
Old Army Corps of Engineers survey marker from 1941. I just found it by dumb luck. You can read the data sheet on this marker here if you want: https://www.ngs.noaa.gov/cgi-bin/ds_mark.prl?PidBox=SA2008
This is definitely the keeper from the hike. I found it near the end and definitely let out a wow when I saw it.
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS M Canon EOS M6 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +1 more
zero214
zero214 Regular Member • Posts: 127
Re: Some IR with the M5 - Oregon/Wallula Gap
Interesting shots Harold, I like the foggy field pic the most, may I ask where did you have your camera converted?
 zero214's gear list:zero214's gear list
Canon EOS M6 Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM +2 more
Tony Speed
Tony Speed Junior Member • Posts: 30
That crooked tree is amazing! How do you mean converted for 720nm specifically? Do you mean you put a lens filter for 720nm highpass?
HaroldC3
OP HaroldC3 Senior Member • Posts: 2,509
This is who I used.
http://www.isaacszabo.com/infrared.html
I paid for shipping to him and he paid it to ship back to me.  I’m happy with the conversion he did.
HaroldC3
I had my camera converted to IR by sending it in to a service and they remove the internal hot mirror and replace it with a specific ir filter (or just a piece of glass if you want full spectrum)
Asla Regular Member • Posts: 383
Hi!
Really good looking photos! Thank you for sharing!
A s l a
Tony Speed
Thank you.
Tony Speed
Meant to ask one more thing (or three...): can you still shoot normal color images using a IR blocking filter? And does the AF still work normally? How about metering?
Thank you.
mdmarqphoto Contributing Member • Posts: 546
Thank you.
Unless you go full spectrum, you will not be able to take normal color images, but AF and metering work fine.
