X100s: Getting a message that internal memory is full???
Bejersey
Bejersey Forum Pro • Posts: 13,871
How do I resolve that?
Rick
Fujifilm X100S
Bob Tullis
Bob Tullis Forum Pro • Posts: 38,078
Re: X100s: Getting a message that internal memory is full???
Highlight your subject line, right click to copy and paste into a Google search (wink-nudge). . . there's a few hits returned. on that string . . here's the first hit in that search that appears to have resolved the same issue for someone else.
...Bob, Bovina NY
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
http://www.flickr.com/photos/bobtullis/
http://www.bobtullis.com
 Bob Tullis's gear list:Bob Tullis's gear list
Sony a7R II Fujifilm X-H1 Sony RX1R II Fujifilm X100F Fujifilm X-Pro2 +1 more
Bejersey
OP Bejersey Forum Pro • Posts: 13,871
I checked the manual. I notice that it doesn't happen when I set the camera to Jpg instead of RAW. And goes away when I insert an SD card.
Rick
Fujijitsu
Fujijitsu Contributing Member • Posts: 910
Rick
Are you shooting without an sd card?
The internal memory is small, so will only hold 1 raw shot or about 30 jpegs, and cannot hold even one raw/fine.
Transfer any shots in the internal memory to your pc or phone, then delete the shots from your camera - and don't shoot without an sd card again (I don't know why anyone would shoot without a card anyway?).  Most other Fuji cameras do not even have internal memory.
 Fujijitsu's gear list:Fujijitsu's gear list
Olympus TG-5 Fujifilm X-E2
Bejersey
I didn't shoot without a card, to my knowledge.  I don't know how to access the internal memory...I have no images when I hit the playback button. So why the "internal memory is full" message?
Fujijitsu wrote:
Rick
Fujijitsu
Fujijitsu wrote:
Rick
Oh.  Strange.
Try this ..... its from the internet, so not sure it it works
Press play
Select Copy then make a right-click
Select internal memory - card
Press OK
Bejersey
Fujijitsu wrote:
Fujijitsu wrote:
Rick
Oh. Strange.
Press play
Press OK
Thank you...I had high hopes, but it's so weird...still showing the warning when I remove the card, am in RAW mode. In JPG mode it doesn't appear.
Thanks again!
Rick
Bejersey
Maybe, when the SD card is out of the camera...the internal memory is not large enough for a RAW file, so the message comes up even though there's nothing there.
Rick
I get a message saying, "cannot execute" pertaining to the internal memory?
Rick
Bejersey wrote:
Fujijitsu wrote:
Fujijitsu wrote:
Rick
Oh. Strange.
Press play
Press OK
Thanks again!
Rick
Brian Homer
Brian Homer Regular Member • Posts: 424
Rick
Rick
Bejersey wrote:
Fujijitsu wrote:
Fujijitsu wrote:
Rick
Oh. Strange.
Press play
Press OK
Thanks again!
Rick
Reckon thats it - in Raw you won't have enough memory if not card.
Not sure its an issue - why have the camera on with no card in it?
Brian Homer
 Brian Homer's gear list:Brian Homer's gear list
Fujifilm X100F Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon 85mm F1.8G Nikon AF-S Nikkor 28mm f/1.8G +7 more
Bejersey
True...I hadn't seen this before, but I have not shot without the card. I was actually reaching into my camera bag on a high shelf and grabbed the camera. The card was not in and probably hit the shutter button.
Thank you for your responses. I sincerely appreciate it
Rick
