Sekonic L308XU flash meter - no 1/200th sec flash synch setting?
Started Nov 16, 2019 | Discussions
Casey Cheung Senior Member • Posts: 1,613
I picked up a new Sekonic L308XU flash meter. I noticed that for measuring flash reading, the synch speed settings goes from 1/125th sec to 1/250th sec. Is there any way to have 1/200th sec setting? That's my max synch speed setting for my camera. Do all Sekonic flash meters not offer 1/200th sec synch speed? Should I not even bother?
tugwilson Veteran Member • Posts: 3,193
Re: Sekonic L308XU flash meter - no 1/200th sec flash synch setting?
Put in 1/3 step increments (P 32 of the manual)
OP Casey Cheung Senior Member • Posts: 1,613
Aaah, perfect, that did the trick. Thank you much!!
jean pierre AKA pete New Member • Posts: 10
I think you  meant page 34.
And I may be quite wrong - but I think the reason is that 1/3 increments are more normal, and that's why it hits 1/200th - instead of jumping it.
jean pierre (pete) guaron
 jean pierre AKA pete's gear list:jean pierre AKA pete's gear list
Nikon D810 Nikon D7200 Nikon D500 Carl Zeiss Makro-Planar T* 2/100 Zeiss Otus 55mm F1.4 +2 more
