Your opinions, please:
Started Nov 16, 2019 | Discussions
uuglypher
uuglypher Regular Member • Posts: 250
Please register your evaluation before reading other responses.
Please grade this image pair by the following scale:
a. no 3D effect
b. slight 3D effect
c. moderate 3D effect
d. strong 3D effect
Any other comments and critiques are welcomed.
Many thanks,
Dave Graham
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Re: Your opinions, please:
Top pair - cross-view  Slight 3d effect.  Note the text has a strong 3d effect.
Bottom pair - parallel view ( using Loreo pixi 3d viewer ) Slight 3d effect. The text has a strong 3d effect.
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
uuglypher
OP uuglypher Regular Member • Posts: 250
Thank you, Brian for your input.
Dave
uuglypher
Wayne Gretzky
uuglypher
Please, when viewing a 3D quad arrangement such as this,
the top (smaller) pair is for parallel view, and
the bottom (larger) pakora is for crossed view.
Thankx
Dave Graham
uuglypher
Wayne Gretzky
pavinder Regular Member • Posts: 280
Somewhere between b and c.
The bird’s right wing and body work well, but I find the left wing (closest to camera) looks much flatter. I’d have expected it to protrude very strongly.
Brian F Flint
I had another look at the images
This time top pair - parallel view
between slight and moderate.
bottom pair - cross view
uuglypher
Thank you, Brian; I appreciate your having another look!
Dave
uuglypher
Wayne Gretzky
3D Gunner Senior Member • Posts: 1,031
The text is not properly positioned. For a proper depth, the text from upper pair must be changed with the text of lower pair.
uuglypher
I fail to see a problem related to the credit text. Are you viewing the top pair by parallel gaze and the bottom pair by crossed gaze?
uuglypher
Wayne Gretzky
Yes. I know how to look at this kind of pictures.
By example, if you look with your eyes crossed at the bottom picture, is easy to observe the text is a little inside the background (inside the hill), and in the same time outside the hill in the upper picture. And vice versa.
Also, the positioning error is easily observed between position of the text relative to some reference elements in the background.
Major Jack Reacher Senior Member • Posts: 1,653
"A" for me.
a. no 3D effect
b. slight 3D effect
d. strong 3D effect
Many thanks,
Dave Graham
Major Jack Reacher, U.S. Army
82Virago Regular Member • Posts: 367
Top Pair mild 3D
Bottom Pair, good 3D, bird actually appears to be above the surface of my laptop.
Were these shot as pairs, or single image converted?
Cheers
uuglypher
Thanks for your response, 82Virago.
This pair is the result of the left eye view having been copied and modified by geometric transformation to introduce specific patterns of detail disparities with horizontal, diagonal, and vertical disparities within the image. The disparities are incorporated by our cortical visual center to configure the 3D illusion presented to our conscious perception.
It has become obvious that most young to middle aged viewers can easily and comfortably perceive the 3D effect from such 2d-to-3D conversions, while, for example, only a distinctly smaller proportion of those over the age of 65 can effectively view them.
I would appreciate knowing your age to add to my data base.
Best regards,
Dave
uuglypher
Wayne Gretzky
Dave,
No problem, I am 58, and usually have no problem seeing '3D'
I have created a few by modding in photoshop, but usually shoot 2 frames. Most of the time I use vertical framing as it is easier to get them to converge.
I used to do them with slides and then just put them into the little hand held viewers, one for each eye.
I wonder how your technique would work with astro photos. It would be cool to get a galaxy to look 3D.
Cheers
uuglypher
Hi, Virago
Thanks for the personal info,
Her is an image pair prepared from a Hubble telescope image found on a Hubble website.
This  image pair ( SBS for parallel view) does nicely reveal this galaxy’s surfacial contours but, IMO, requires more refinement of the specific technique used to produce it. I have just begun  experimenting with complementary homologous and complementary heterologous transformations and there is much refinement necessary before the complementary technique is ready to be included in the book!
Please let me know what you think of this pair.
Best
uuglypher
Wayne Gretzky
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
I have to admit that I only see a slightly warped image of this astrophoto, which also has uncomfortable eyestrain while fusing it.
That said, I have seen far superior conversions of astrophotos.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
uuglypher
Hi, Wayne,
Thanks for registering your opinion on this galactic pair.
Would you also  please comment on the image pair originally posted in this  thread - the crane in flight.
Come to think of it, I checked back and find that you have never mentioned your age. It would be a helpful addition to my data set if you would consent to do so.
many thanks,
Dave
uuglypher
Wayne Gretzky
That is pretty cool! I can definitely see texture and depth.
It is a good thing this works, imagine try to shoot 2 frames spaced apart, like a million miles apart!
I have thought of doing the moon from 2 separate locations an hour apart or working with someone in a different location.
If you have or do one with the moon, I would love to see it. When I finally get my killer M31 shot, maybe we can look at doing it.
Cheers
uuglypher
Hi, Virago,
Here’s a moon pulled from the internetI did some time ago
and meant to work on to correct the out-of-round problem,
But you
do get an idea of what can be done. If you have a closer view
it would be fun to see what could be done with surface crater contours.
Best regards,
Dave
uuglypher
Wayne Gretzky
This moon one is interesting. If I view in a small version, it looks as though it is pushed into the center. Think stepping on a tennis ball.
If I view it at the largest size, it appears as though painted on a glass ball, the backside and I view the details through the glass.
Cheers
