Inverted tripod clamp?
Started 10 months ago | Discussions
Montanawildlives Senior Member • Posts: 1,144
I'm looking for a clamp that has the receptacle for a tripod mount on the bottom and a clamp on the top . I've seen the opposite, with the screw end to be inserted into a camera on the top and the clamp on the bottom.
I want this so I can use a small table to tripod to position a clamped item (spoon full of soup) anywhere I want on the table .
It's like the plamp (in terms of intended use) but instead of a table clamp on the bottom it will have the screw hole on the bottom so I can attach it to my table top tripod.
I don't want the plamp because I don't want to be restricted to the edge of the table and I'm looking to hold heavier items than a flower.
Does such a thing exist?
Thanks!
 Montanawildlives's gear list:Montanawildlives's gear list
Fujifilm X-T1 Nikon Z50 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Teleconverter TC-14E III +7 more
Ellis Vener
Ellis Vener Forum Pro • Posts: 13,724
Re: Inverted tripod clamp?
It sounds like you want something like a Manfrotto Magic Arm to attach a clamp to.
or maybe the clamp discussed here? https://www.dpreview.com/forums/post/63230807
Thank --
Ellis Vener
To see my work please visit http://www.ellisvener.com
Or on instagram @therealellisv
 Ellis Vener's gear list:Ellis Vener's gear list
Sony RX100 VII Nikon D850 Nikon Z7 +1 more
Seedeich Senior Member • Posts: 2,922
The Manfrotto Nano Clamp has tripod threads at the bottom.
You might need a piece of rubber, leather or foam to hold small items.
OP Montanawildlives Senior Member • Posts: 1,144
Thanks Ellis and Seedeich! Seedeich, did you take that picture especially for me? That looks like the ticket.  Thanks!
Yes, I made the picture especially for you
These Nano Clamps get a lot of use in conjunction with a small ballhead.
Ellis Vener
Handy little buggers, aren’t they? πŸ‘πŸ»
Ellis Vener
Yup, I have a couple of them.
Superclamps can do the same, but they are a lot bigger and heavier.
Ellis Vener
Usually I think of Super Clamps  / Mafer Clamps and Cardellini/ Mathellini clamps as being the base  you attach to something to support something else and Nano clamps being used on the other end of the support  for holding small things like that spoon.
Ellis Vener
It depends on what I want to support. Super Clamps can obviously support a lot more weight and they are compatible with 5/8” spigots.
But I use both clamps as base and front.
To slip a Nano Clamp with ballhead and flash adapter into a bag is very easy. I wouldn’t do that with a Super Clamp unless I need it.
Working with product development I’m used to reverse and lateral thinking. I’m also used to make pictures to communicate visually.
