Capture One Preview RAW Issue
histogram Junior Member • Posts: 34
Hello . I started to use Capture One with Fuji x-t3. I am happy with that intergration between these. But there is a serious problem. I finish my editing after I export to photoshop. But the colours and some highlights are different. After I search at the internet it is about preview. When I look at full size there is no problem between raw and tiff(I tried psd,jpeg) export. When I looked at fit in screen there is a  difference. Capture One doesn't render highlights recovery and chromatic fixings in Raw. I post 2 photos. How can I fix it. If I can't I back to lightroom as well. My screen is 2k dell u2713h
First photo is tiff export preview
Second photo is Raw preview
Fujifilm X-T3 Phase One Capture One Pro
IanYorke Veteran Member • Posts: 3,621
Re: Capture One Preview RAW Issue
More information please
It is not normal behavior.
Working perfectly on my Win 10 (1903) fully patched system, 2K Dell 27 inch.
OS version?
Try turning off GPU acceleration?
Make sure you have the latest GPU drivers installed?
Is your monitor calibrated?
What have you set the preview resolution to?
Are you using Recipe Proofing, the spectacle icon on the top toolbar?
If you set up a recipe for the output to what you use for PS eg tif, aRGB, full size the Recipe proofing will reflect the output.
Hope this helps.
Ian
OP histogram Junior Member • Posts: 34
OS version?
Hope this helps.
Ian
Hello Ian. Sorry I didn't give much info
My win 10 is same with you 1903.
I try GPU acceleration turning off. Nothing change. I have latest nvidia drive. My card is GTX 680
Yes it is calibrated with i1display pro. I will calibrate again.
My preview is 2650px
I tried proofing, but actually nothing changes or I did something wrong I tried some different dimensions but it was same. I saw same issue on lightroom years ago but there is no problem in Lr.
PS: These are screenshot from pc. I am sorry I forget to say that.
CAcreeks
CAcreeks Forum Pro • Posts: 14,080
histogram wrote:
... Capture One doesn't render highlights recovery and chromatic fixings in Raw. 2 photos:
I don't see any significant difference in color, on my laptop or a standard sRGB monitor.
The first image (TIFF preview) has brighter highlights. Are you saying the brighter highlights are what you want, part of your highlight recovery technique? If so, you have a question for Capture One technical support. Why does it not render highlight recovery in Raw previews?
Personally I like the darker highlights.
OS version?
Hope this helps.
Ian
Do you have a recipe set and the spectacle icon turned on (orange), example shown below:?
Like others I just see highlight shifts between the two images.
Ian
Tom-C Senior Member • Posts: 1,276
Are you exporting the original or variants?
If variants, what ICC Profile is specified? What is selected for Open With?
How are you viewing the preview? I don't see a preview option in the export dialog in my copy of Capture One 12.
 Tom-C's gear list:Tom-C's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV
OS version?
Hope this helps.
Ian
Ian
Hello Ian sorry for late answer. I did it but nothing change. It is very interesting. I export psd after I check, PSD looks good but raw is still too many highlights. But in %100 zoom both looks same.
Hello sorry for late answer. First image fujifilm x-t3 raw file. Second one export to tiff. They are both same image in same adjustments. When I look at %100 zoom they look same but when I look fit in screen mode. It is looks like this.
Hello. I export at srgb. My monitor calibration same srgb. In %100 zoom both image looks same. But in "fit in screen" they look different.
CAcreeks
Possibly it's just different downsampling algorithms for "fit in screen" view.
Downsampling tends to darken the overall image, so perhaps Capture One is compensating.
Yess I totally agree but how can I fix this ?
CAcreeks
I would start with Capture One technical support.
