Quick set menu on dp1s
Started Nov 5, 2019 | Discussions
docmaas
docmaas Veteran Member • Posts: 7,061
The dP1s addendum to the dp 1 manual says the following:
How to use the Qs (Quick Set Menu) When the camera is in the Still Image Mode, the Quick Set Menu will be displayed by pressing the ( w-t) button. (By pressing the button again, it is possible to switch to Qs1 or Qs2.) Select the desired Menu by pressing the 4-way controller and change the setting.
What is meant by "still image mode"?  Is it something different from just not being in "movie mode"?  I've been thrugh the manual and don't see it used other than as a general term.  However when I'm in any of the still image modes I can push the w-t button till the cows come home and nothing happens?  Does this work on anyone's dp1s camera?  Apparently, this is where it was first introduced.
If you have one that works as described a set of instructions would be highly appreciated.
thanks,
Mike
"Laoma shitu" "An old horse knows the road" Chinese Proverb "Dao ke dao, fei chang dao. Ming ke ming, fei chang ming" Laozi
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
Pentax Q-S1 Sigma DP1s
allineedislight Senior Member • Posts: 1,309
Re: Quick set menu on dp1s
The mode dial wheel on top of your camera determines the main modes of operation.
So "still image mode" refers to the  M, P, A, S modes, as opposed to Movie mode or Voice record mode, or the Set Up mode.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
I owned a DP1s but don't remember how to use the Qs.
Have you allocated those buttons to do something else while in PASM? Or does the default for those buttons exclude the Qs?
Observe that the Qs icon above is grayed out ...
Do you need the latest firmware to get the Qs function ... like you needed the latest on the SD14 to get 50 ISO?
Sorry I can't be more precise ...
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
docmaas
OP docmaas Veteran Member • Posts: 7,061
Thanks Ted.  It was set to off.  Once it was set to qs everything works as expected.
Your pedantry dominates once again.
Mike
Maurice Maeterlinck
