ESP vs Spot Metering?
Started Nov 5, 2019 | Discussions
smithaa02 Regular Member • Posts: 252
So I'm familiar with the basics of ESP vs Spot.   But I am more curious to know the nuances of spot metering (especially on the TG series).
Can you achieve identical results between the two by merely adjusting EV?  Or does spot metering do other hidden things under the hood?
- Does spot metering have different focus method (relative to ESP)?
- Will spot metering result in a different AWB calculation?
- Will spot metering affect contrast?
Also does  spot metering affect the black point?  When I change the EV, usually the blacks stay black.   But this doesn't make sense if I'm changing SS/ISO/A.  Shouldn't the blacks change to say a dark grey with more light?  I assume then that Olympus changes their contrast algorithm to compensate for what the sensor provides.  If this is the case, then do black points change for spot metering?
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,604
Re: ESP vs Spot Metering?
It depends on the scene lighting. ESP mode meters at the center of the scene and applies a slight bias towards the light value found there. But, it also evaluates the rest of scene and attempts to come up with a exposure to balance the brightest areas with the darkest ones. If the scene has perfectly flat lighting, the ESP and Spot metering values will be pretty close. It doesn't make any sense to use spot metering then change exposure to the evaluative value.
My problem with the TG series spot metering mode is it uses a fairly small area. I only use it when it makes sense. Wished a center weighted mode was offered.
Why would you think spot mode changes other parameters? It's just limits where light levels are measured.
No, the 2 functions are independent of each other.
AWB attempts to determine the color temperature of the light source. It needs to evaluate the entire scene. But if metering causes clipping in any of the color channels, white balance calculations will probably be corrupted.
No
No, that's a function of the JPEG engine. It doesn't care how the scene was metered.
If you use positive compensation, the blacks will move up in level. It's a global adjustment. But the JPEG engine will squeeze those darker values into a fairly small range of the tone curve. Again, the JPEG engine doesn't consider what metering method was used.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Olympus Tough TG-3 Fujifilm X30 Canon EOS 7D Mark II Nikon D500 +19 more
elliottnewcomb Forum Pro • Posts: 18,223
metering area to follow focus area location.
Not sure about your model. I actively change metering from center to spot, and have my Stylus 1 set so spot metering area location automatically follows wherever I move spot focus to.
In addition, because I shoot shutter mode so often, I find having AEL set up on a rocker/button a big help. I simply aim at a brighter/darker area, choke/open exposure, lock it, back down to my subject.
Elliott
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX1R Sony RX100 III Olympus Stylus 1s Sony RX100 VI Sony Xperia XZ +1 more
Enders Shadow
That's not a option with the TG series. When Face Priority a enabled, a slight exposure priority is assigned to the area(s) where faces are detected. However, the entire scene is still evaluated for exposure.
There's no shutter priority mode (or manual exposure) on any TG. And, with a limited number of buttons, there's no seperate AEL option or the ability to reassign button functions.
Phil
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,899
On my pocket zooms I also have no shutter priority (SH-50 and SH-1). I do have manual exposure, which permits me to change ISO, shutter speed and aperture, with the EV indicator telling me how far off I am from the correct exposure.
With spot-metering on stills it is very rare that I am so far out so I cannot correct in PP. I mostly use spot-metering for the moon.
For following a cruise ship out of the harbour on video, spot-metering causes the sky to brighten and darken as the ship goes with the shaded side towards me to the sunlit side towards me. Same thing happens with flying gannets moving in and out of the center spot when using spot-metering.
My understanding is that while the TG series does vary from my SH-series pocket zooms in the way lighting is metered, in my opinion ESP is still preferable for shot-to-shot consistency in still photos.
Henry
Henry Falkner - E-M10 Mark II, SH-1, SH-50, SP-570UZ
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
