Equestrian demonstration
Started Nov 2, 2019 | Discussions
Fred_Last Contributing Member • Posts: 525
brentbrent Veteran Member • Posts: 5,766
Re: Equestrian demonstration
Always nice to see the GX7 representing!  Pretty nice, though ISO 3200 isn't really the GX7's happy place.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
R Liewenberger Senior Member • Posts: 1,824
Fred_Last wrote:
Not bad, but could it be focus in the first one is more on the background than on the girl/horse?
Liewenberger
JosephScha Veteran Member • Posts: 7,249
Very nice especially for ISO 3200.  I try to avoid going up there ...  maybe I should be a little more willing.
I understand why; indoor lighting and you needed 1/500 second.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
What would make you say that?  Look in the lower left corner at the white stand for the jump bar.  It's closer to you than the horse, and it's perfectly sharp.   I think 1/500 second (without panning, there is no sign of panning) did not quite freeze the moving horse.  Not enough to see all the individual hairs, at least.
js
OP Fred_Last Contributing Member • Posts: 525
Yes I understand the high ISO limitation of M43. Thank goodness I have a 35-100 f2.8 which gained me precious EV step ( see my other post in the Fuji forum , that was really struggling ....)
Well, compare it to the second one, where the horse looks definitely sharper in focus than the background. Same shutter speed, movement/position of the horse comparable to what it is the first one.
Liewenberger
