What might work best for me...
Started Nov 1, 2019 | Discussions
Massao Senior Member • Posts: 2,580
Re: What might work best for me...
McSpin wrote:
Joseph Tainter wrote:
Try one of the K-5 series cameras (K-5, K-5II, K-5IIs, all the same sensor). I passed on the K-3 because the K-5 cameras give better low light/high ISO noise performance.
Joe
Isn't the my K-50 sensor the same as what's in the K-5?
Yes, I think its the same sensor used in K-30, K-50, K5, K5ii, and K5iis.
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
OP McSpin Contributing Member • Posts: 504
Massao wrote:
Well, its not the sensor size that will affect the DOF, but rather the difference in focal length of lenses in this case. ISuppose you want to capture a 24mm FF-equivalent frame of view. A smaller sensor (1” or smaller), will have to use a tiny focal length in order to give you the 24mm FF-equivalent image. But, since you are not actually using a lens with 24mm focal length--- probably something like 6-8mm lens on a small sensor camera to get the same frame of view as a 24mm lens on a FF camera, your DOF is increased. So, the short answer to your question is YES, a small sensor camera will help you in this scenario, but not because of sensor size, rather the difference in focal lengths of lenses.
Yes, that I knew. I was just referring to cameras that give the same field of view.  The ones with a small sensor will always give a greater depth of field with the same field of view. I also realize that a small sensor with a high pixel density will add some noise,. The object is to get a low-noise, large depth of field with acceptable resolution. I may have to get my hands on a 1" sensor camera to find out for sure.
Yes, but it doesn't seem like you have any other choice. You can't use flash or other lighting, and you don't want shallow DOF of longer focal-length lenses used on DSLRs Sensor tech has improved a lot. You will be surprised with 1" sensor results
Kind regards,
Massao
DougOB wrote:
DougOB wrote:
McSpin wrote:
I wondered about that, but the KP has a higher pixel density than the K-50, yet has lower noise. I was guessing that sensor technology was most important and that a recently produced sensor might be better.
In short... yes.
To follow up on my own post... I took a look at the Photons to Photos web site (http://www.photonstophotos.net/) and the KP at ISO 6400 has a "Photographic Dynamic Range" (their terminology) of 6.32, which is about the same as either the K-50 or K-3 at ISO 1600. The K-70 is pretty close to the KP.
Doug
That may give a wrong impression: (1) x-axis represent ISO settings in camera(s), and after VW’s cheating, I don’t trust the ISO settings given by manufacturers too much. (2) Both Nikon and Pentax use sensors by Sony, and I doubt any sensor was given exclusively to Pentax alone; however, some of the difference in these charts between similar aged/year Pentax and Nikon sensors are very “pronounced”--so much that it is hard to believe they were using same sensors. (3) Pentax does some sort of noise reduction—I don’t know if that has been incorporated/adjusted/controlled in these charts. In sum, while these charts are helpful, I would never base any purchase on these alone 😉
Kind regards,
Massao
FingerPainter Forum Pro • Posts: 11,576
Sensor size will be irrelevant
McSpin wrote:
When I compare photos, I want the same field of view. On a full frame, f/8 has a shallower depth of field as a crop sensor at the same field of view and depth of field. That means that on the crop sensor I can go to f/5.6 and a lower ISO to reduce noise. On a 1" sensor, it would be closer to 2 stops. On the other hand, the larger sensor gives me less noise at a given aperture. It seems like the advantage of each cancel each other out, but without using a good 1" sensor camera, I'm guessing.
It is a good guess. If you have the same field of view, the same DOF and the same shutter speed, you'll get the same shot noise no matter the sensor size ... as long as the sensors are equally efficient.
So, for this application, choose the most recent/advanced sensor you can get, regardless of its size.
DougOB
DougOB Veteran Member • Posts: 3,176
Joe
Pretty close except the version of the sensors used in the K-5, K-5ii & K-5iis are 14 bit RAW output vs 12 bit for the K-30, K-50, K-01, etc.
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +36 more
DougOB
Massao wrote:
DougOB wrote:
DougOB wrote:
In short... yes.
Doug
On these numbers alone - no, of course not.
However my personal experience is the KP is about 2 stops better than the K-3 at these ISOs, which does happen to correspond to these numbers (note I never actually compared the K-3 to KP  on this site before this thread).
Doug
DougOB wrote:
Massao wrote:
DougOB wrote:
DougOB wrote:
In short... yes.
Doug
Doug
That is very good. I trust this more than those graphs
Kind regards,
Massao
Massao wrote:
... You will be surprised with 1" sensor results
At the price they're charging for them, they should, LOL.
DougOB wrote:
Massao wrote:
DougOB wrote:
DougOB wrote:
In short... yes.
Doug
Doug
When I look at DPReview's image comparison charts, I see about one stop difference, maybe a bit more, but that is just my crude estimation based on what my eye sees on DPR's crops.  Still, a stop or a bit more is worth looking in to.
