What might work best for me...
Started Nov 1, 2019 | Discussions
McSpin Contributing Member • Posts: 504
I have an application where I need a large depth of field and as low noise as possible. The subject is moving and in relatively low light and only 1-3 feet distance. Shutter speed has to be at least 1/160 and I can't use a flash.  If I switch to a small sensor camera - like a 1" sensor, I'll triple the depth of field at a given camera setting and the same focal length. Therefore, I can use a lower ISO to achieve the noise level I'm looking for. I don't think I need the extra resolution of the larger sensor since these images are for web-viewing only.
I've been analyzing the pros and cons of each, but thought maybe someone else had a similar situations and has done the hands-on comparison.  So, is it a wash if I use a small sensor with greater depth of field at a lower ISO, or would there be an advantage, since I don't need the extra resolution of the larger sensor?
I'm currently taking these shots with a k-50 and a K-3. Typically, the ISO is around 6400 at the aperture and speed I need. The photos are a bit noisy and noise reduction reduces detail too much.  I experimented with a K1 and the depth of field was so small that I had to reduce aperture size a lot - which gave me images similar to the others since the ISO had to go even higher to compensate.
Pentax K-1 Pentax K-3 Pentax K-50
DougOB
DougOB Veteran Member • Posts: 3,176
Re: What might work best for me...
A crop of a larger sensor will give you the same result as a small sensor if they are covering the same scene and same perspective.  If the small sensor has more pixels than the cropped large sensor it mean high pixel density / smaller pixel size which probably means more noise.  A KP will give you 1-2 stops lower noise than your K-3 (based on my experience)
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +36 more
MightyMike Forum Pro • Posts: 41,691
If you can use a solid bright light source then maybe that would help you achieve the best result
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
OP McSpin Contributing Member • Posts: 504
I've tried that, but I'm taking photos of fish and they are frightened by the suddenly brighter light. I can put the light on for a few days and they get use to it, but that is too time consuming. I need the photos right away most of the time.
I wondered about that, but the KP has a higher pixel density than the K-50, yet has lower noise. I was guessing that sensor technology was most important and that a recently produced sensor might be better.
DougOB
In short... yes.
Doug
DougOB
Maybe if you lower the water temperature they will swim slower and you can use a slower shutter speed
Doug
Doug
LOL, you'd be surprised at how little movement it takes to ruin a shot when you're only 18" away. Of course, if they were in a block of ice, no problem (at least with the movement).
DougOB
DougOB wrote:
In short... yes.
To follow up on my own post... I took a look at the Photons to Photos web site (http://www.photonstophotos.net/) and the KP at ISO 6400 has a "Photographic Dynamic Range" (their terminology) of 6.32, which is about the same as either the K-50 or K-3 at ISO 1600.  The K-70 is pretty close to the KP.
Doug
DougOB wrote:
DougOB wrote:
In short... yes.
Doug
That would be significant. Thanks,
Joseph Tainter Forum Pro • Posts: 11,494
Try one of the K-5 series cameras (K-5, K-5II, K-5IIs, all the same sensor). I passed on the K-3 because the K-5 cameras give better low light/high ISO noise performance.
Joe
DougOB wrote:
DougOB wrote:
In short... yes.
Doug
After looking at this linked site, I was trying to figure out the relationship of dynamic range to noise, and don't see the connection.  Can you explain this?
Joe
Isn't the my K-50 sensor the same as what's in the K-5?
kypfer Contributing Member • Posts: 985
Nope ... "duff science" I'm afraid.
Acceptable depth-of-field varies with sensor size.
If I take a "full-frame" lens and mount it on my APS-C (effectively half-frame) camera, the depth-of-field markings on the lens become "one stop out", that is to say, if I want "f/8 depth of field", as marked on the lens, I need to set the aperture to f/11.
As for photographing fish in a tank, I've done some in the past and don't remember any problems with flash disturbing the fish, though I do remember having to "try and try again" to get a result with no unwanted reflections. This was in the days of film, with no immediate gratification of instant preview, having to wait to get the film processed before I was sure I'd achieved what was wanted I have vague recollections of diffused flashguns on extension cables, but can't remember the details
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
DougOB
McSpin wrote:
DougOB wrote:
DougOB wrote:
In short... yes.
Doug
I am sure that my explanation will be corrected... But in this context think of photographic dynamic range as similar/related to signal to noise ratio.
From the web site: "The second test is for Photographic Dynamic Range (PDR).
This is a practical measure which incorporates all noise sources and targets a Signal to Noise Ratio (SNR) that is visually acceptable under standard viewing conditions.
PDR is the most popular measure published at PhotonsToPhotos."
(http://www.photonstophotos.net/Investigations/Measurement_and_Sample_Variation.htm)
Doug
When I compare photos, I want the same field of view. On a full frame, f/8 has a shallower depth of field as a crop sensor at the same field of view and depth of field.  That means that on the crop sensor I can go to f/5.6 and a lower ISO to reduce noise. On a 1" sensor, it would be closer to 2 stops.  On the other hand, the larger sensor gives me less noise at a given aperture.  It seems like the advantage of each cancel each other out, but without using a good 1" sensor camera, I'm guessing.
Using a flash is challenging because although it doesn't frighten this fish to an extreme, the images don't look realistically when the light is being bounce off the front of the fish (very reflective scales) vs coming from above, like it would from aquarium lights. I've experimented with this for years  with tens of thousands of images and the best ones are with light from above that is bright enough. It's getting it bright enough without freaking out the fish that is the challenge.  Part of that is because the aquariums are kept on the darker side on purpose.
Thanks!
I've done a little research into the methods I used ... the flashgun(s) were "face-up" in the aquarium hood, above the splash-guard, effectively in the same space as the normal aquarium lights, with diffusers fitted and the power settings adjusted to give just enough light for a good exposure. Nett result was very similar to the lighting from the aquarium lamps (flourescent tubes in my case), but the colour balance needed some tweaking in the darkroom ... it'd be a lot easier with Photoshop and a digital image! The flashguns would have been suitably waterproofed in plastic bags
Unfortunately, this is a hatchery situation with no hoods on the tanks. I've tried setting the flashes on a diffuser sitting on top of the tanks, but it's still too harsh.  I may have to try building a custom light box to bounce the flash off.
Here's an example of light from above, without flash. As you can see, I can't even get the whole fish in focus easily. Getting multiple fish in focus is all but impossible.
Massao Senior Member • Posts: 2,580
Well, its not the sensor size that will affect the DOF, but rather the difference in focal length of lenses in this case. ISuppose you want to capture a 24mm FF-equivalent frame of view. A smaller sensor (1” or smaller), will have to use a tiny focal length in order to give you the 24mm FF-equivalent image. But, since you are not actually using a lens with 24mm focal length--- probably something like 6-8mm lens on a small sensor camera to get the same frame of view as a 24mm lens on a FF camera, your DOF is increased. So, the short answer to your question is YES, a small sensor camera will help you in this scenario, but not because of sensor size, rather the difference in focal lengths of lenses.
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
