TG5 for snorkeling: Use flash?
Started Oct 30, 2019 | Discussions
Hawkmooon Regular Member • Posts: 205
I will be going to the Galapagos Islands and doing a lot of snorkeling.  I'll be bringing my TG-5 which I've used for some snorkeling before.  I have not had a lot of success using the flash underwater (it usually seems to highlight the sediment floating in the water).  However, I know that the best way to improve underwater photograph is to add light.
What do you recommend for snorkeling?  If I should be using flash, are there particular settings that are best?  Or do I put it on "auto" and let the camera decide.
Any advice would be appreciated!!
Olympus TG-5
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: TG5 for snorkeling: Use flash?
If you use on-camera flash, you need to:
a. use a diffuser over the flash (hopefully it comes with one), and
b. be extremely close, like within a foot or so.
On-camera flash with diffuser should work OK for macro subjects.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
OP Hawkmooon Regular Member • Posts: 205
The flash is built in to the TG-5 so I don't know of any diffuser that would work (and didn't even know that diffusers were a thing for underwater photography).
daveco2
daveco2 Contributing Member • Posts: 953
In order to eliminate particulate backscatter underwater you need to move the flash (strobe) to the side of the subject, away from your lens.  If your flash is fixed on the camera, then it would probably be better not to use it at all.
For snorkeling, you'll be shallow and you'll have to rely on ambient light, which in most cases is good enough.  Flash in the shallows doesn't add much.  In any case, in the Galapagos, you'll be doing mostly wide angle shots, and if you were going to use a flash, it would have to be pretty powerful to cover a wide field, and you would be better off with two, one on each side of the scene.
There are many tutorials on the web that give a good idea of what's needed to shoot with flash (strobes) while avoiding backscatter.
 daveco2's gear list:daveco2's gear list
Sony RX100 Sony a7R II Sony a7R III
PHXAZCRAIG
Is there an optional housing for the camera?   That's where you'd most likely find a diffuser.  There are various do-it-yourself ideas for them, but all I know are above-water hacks.
www.cjcphoto.net
kelpdiver Veteran Member • Posts: 5,564
they're an essential item for compact cameras, generally built into the camera housing, like the Olympus one. But snorkelers don't need the housing for depth- main benefit would be crash proofing.  People have had levels of success cutting pieces of milk jugs and attaching over the front.
I did see this item though: https://www.adorama.com/iomfd1.html?gclid=Cj0KCQjw6eTtBRDdARIsANZWjYaCspxontp-lQUkHD9OIfyNUKSSYgJOdDmERXijeP_yjNUKyDhRGHIaAlLdEALw_wcB
But...this is only going to help for short range, say 1-2' max.  A good $600 strobe still only gives you a range of about 6' or so, and the little ones in these cameras don't come close.  And because the flash is so close to the axis of the lens, any particles in the water will reflect and distract from the shot.  This is why strobes are on arms further away, and aimed so the strobe light doesn't illuminate in front of the lens.
You could also just aim an LED light in a separate hand.
brousseb
brousseb Regular Member • Posts: 193
Disable the flash, especially for the Galapagos where there is quite a bit of particulate in the water compared to other places.
Shoot in RAW (your camera can do that), alternatively I think the TG5 has an underwater mode, you can try that but you may get some nasty results in shallower depths.  RAW will be your best option.
 brousseb's gear list:brousseb's gear list
Panasonic ZS100 Panasonic LX10
Thank you all for the advice.
Yarks
Yarks Junior Member • Posts: 25
I find the flash a must for macro shooting, and occasionally useful for landscape. My dive housing has a diffuser which makes a big difference. That said, using flash oterh than macro I often pickup too much particulate, even in exceptionally clear waters, if I'm trying to shoot into the distance for landscape or a further away fish.
I use a TG3, but have to imagine the TG5 is even better.
 Yarks's gear list:Yarks's gear list
Ricoh GR II Fujifilm X-Pro2
Dann-Oh Contributing Member • Posts: 894
If you can get your hands on a underwater flashlight that would help out as well.  You can hold the camera in your right hand, flashlight in left hand.  the differance in angles should help you eliminate the backscatter
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
