GX7 vs GX80
Started Oct 30, 2019 | Discussions
DeathArrow Veteran Member • Posts: 3,388
GX7 vs GX80
I intend to get one of those two. Is there any reason to prefer one over the other? They look pretty similar to me spec wise.
Thanks!
 DeathArrow's gear list:DeathArrow's gear list
Sony RX100 VA Nikon D300 Nikon D610 Nikon D750 Nikon AF Nikkor 50mm f/1.4D +6 more
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85
ClaudeVoyage Regular Member • Posts: 217
Re: GX7 vs GX80
5
GX 80 has dual IS and 5 axis IS
it does not have a high pass filter on it.
 ClaudeVoyage's gear list:ClaudeVoyage's gear list
Canon G5 X II Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Lumix DC-ZS80 Panasonic G95 +1 more
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Re: GX7 vs GX80
GX7 advantages:
-Tilty Evf
- 1/8000 shutter
- flash with master wireless trigger
- better grip
- 12 bits electronic shutter
Gx80 advantages:
- much better 5 axis IBIS
- quieter shutter with greatly  reduced shutter shock
- quicker operation, newer processor (but sometimes weird artifacts in jpeg)
- no aa filter ( sharper images)
- charging of the battery through USB
- DFD focusing
- 4k video and 4k photo mode
I'd get the Gx80 if I were you. I replaced the gx7 with the Gx80 and the only thing I regret is the better grip, but you can still add one.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
brentbrent Veteran Member • Posts: 5,766
Re: GX7 vs GX80
Some comparison info in this post:
https://www.dpreview.com/forums/post/59716801
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
alcelc
alcelc Forum Pro • Posts: 19,003
Re: GX7 vs GX80
photofan1986 wrote:
GX7 advantages:
-Tilty Evf
- 1/8000 shutter
- better grip
5 C modes
12 bits e-shutter
Gx80 advantages:
& DUAL IS
- DFD focusing
3 C modes
10 bits e-shutter
Zebra alert
Auto ISO in M but no EC
Dial Operation Switch to add temporary features to front and back dial
4 bracketing modes
Post Focusing
1 stop better high ISO performance
Albert
alcelc
Re: GX7 vs GX80
Might I say that the evf and integrated flash of both models are the same. Others on the list are true.
Albert
MOD Tom Caldwell Forum Pro • Posts: 46,352
Re: GX7 vs GX80 “Mr In-between”
6
They are certainly a progression but I use my GX7, GX85 and GX9 as a set with no particular attention to which camera get used for what purpose with which lens.
Each camera is a little better than its predecessor but the GX7 was such a great camera when it was first released it is a very hard act to follow.
I doubt if I will ever be out of love with my GX7 and I suspect that I would have been almost as happy with 3 x GX7 cameras as the present ones that I own.
But if it comes to just one camera then why not consider a GX9 instead of the GX80.
The GX80/85 is not as cheap as the classic defining GX7 version and not as good as the more presently competitive GX9.  A sort of “Mr In-between”.
Tom Caldwell
alcelc
+1.
IMHO GX9 is a major improvement on GX7. But is only marginally for GX85.
If I want to upgrade GX7, GX9 is the best option on feature. However, currently GX7 (if there is still new copy in the market) and GX85 are dirt cheap. As per my shopping yesterday, GX9 is around 30~40% more expansive than GX85... On cost performance, GX85 is still the best buy today.
The same reason I picked G85 instead of G95 (to upgrade GX7) couple of months ago. 😁
Albert
larsbc Forum Pro • Posts: 18,282
Re: GX7 vs GX80
Thanks!
I have a GX7 and couldn't bring myself to upgrade to the GX80 because:
  • No tilting EVF.
  • 1080 video didn't look as good as GX7's.
  • No dedicated switch for AF-S/AF-C/MF.
I ended up augmenting my GX7 with a G85 which I suggest you have a look at because its price is very low these days and it has some nice benefits over the GX7 and GX80:
  • Much better IBIS than the GX7 and a bit better (maybe a stop?) than the GX80.
  • Much better EVF.
  • Weather proof.
  • Longer battery life.
  • Better handling/control layout.
I also ended up getting a GX9 recently which is more of an upgrade (with no backward steps...none of my complaints about the GX80 apply to the GX9) to the GX7 than the GX80, IMO.
BUT if it's going to be only between the GX7 and the GX80 then I'd recommend the GX80 simply because the much better IBIS is worth it.  Unless, of course, you like shooting 1080 video in which case I think the GX7 + a lens with OIS is a better choice.
OP DeathArrow Veteran Member • Posts: 3,388
Seeing that you own both, can you kindly give me some answers?
Is the IQ worse in e-shutter mode on GX80/85 vs GX7? I see one uses 12bit and the other 10 bit.
Is a visible difference on dual IS 5 axis stabilization in GX80/85 vs the one in GX7?
I ask because I found them at about the same price. I don't want the best possible camera, I want a cheap small camera with tilting screen, e-shutter and touch to focus so I can take a photo without being noticed.
Re: GX7 vs GX80
Thank you for recommendations. Having better features and ergonomics doesn't matter much.
I need a small camera with e-shutter, tilting screen at the lowest price to use when I don't want being noticed.
Re: GX7 vs GX80
Would 10 bits with e-shutter on GX80/85 mean worse IQ than 12 bits on GX7? The majority of shooting would be with electronic shutter so that is important to me.
Is it a big difference between dual IS and 5 axis on GX80 vs the IS in GX7? I won't use long lenses, I will use a 17mm or 20mm prime.
maggiemole Senior Member • Posts: 1,988
Re: GX7 vs GX80
If you are not intending to use long lenses, I suggest the difference in IS is irrelevant. I have both cameras: intended to sell the GX7 but find the toggle switch between af and mf too valuable to lose. I can't say the 10 bit vs 12 bit difference has ever made the slightest impact.
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
Boombuia Regular Member • Posts: 164
Re: GX7 vs GX80
if stabilisation is not very important for your photography (which is...?), perhaps you need to look at the Panasonic GF7/9/10(GX800). They are smaller than GX7/80/9, with have e-shutter and tilt screen, and they are certainly very cheap.
In the same price range as the GX7/GX80, you could also look at the Olympus E-M10 Mark ll, which offers similar feature set.
 Boombuia's gear list:Boombuia's gear list
Panasonic ZS200 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GF7 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +8 more
Re: GX7 vs GX80
I would use the camera just when I want to get photos without being noticed. Street and documentary mostly.
I'd still want to have an EVF.
Yes, but it is bigger.
photofan1986
Re: GX7 vs GX80
Yes, but you would only notice when pushing the raw files or if you use icontrast to boost the shadows. You'll get more noise from the 10 bits files. It's noticeable.
Yes. I'd say you can get about 1 or 2 stops gain from gx7 ibis, and about 3 to 4 from GX80. To me this is a big difference.
onlyfreeman
onlyfreeman Senior Member • Posts: 2,498
E-Shutter
Have you noticed a difference in the way e-shutter works? What's the max e-shutter speed on the GX7?
Might be worth mentioning that the GX80 apparently has a quieter shutter, is that useful?
 onlyfreeman's gear list:onlyfreeman's gear list
FastStone Photo Resizer Paint.net
Re: GX7 vs GX80
Reading replies here and some reviews, it seems that GX85 is the better camera, apart from that 10 bit with electronic shutter.
I wonder what that means. The camera captures full data and discards part of it when writing the raw file or it just captures 10 bit data?
I hope it doesn't mean more noise beside reduced DR. I can live with reduced DR but I don't like more noise.
Re: GX7 vs GX80
The popup flash mechanisms differ a bit, but the review of the GX85 here on DPR does say that it can be directed at the ceiling, so you are apparently correct on that.
The EVF panels may be identical, but several here have written that they find a difference in EVF use between the two cameras, with the EVF of the GX85 less pleasant to use, perhaps because of poorer optics in front of the EVF panel.  I haven't used a GX85 so I can't say, but the comment has been made here by folks who usually seem to be discerning and careful.
Brent
cameralight Regular Member • Posts: 379
For your intended uses, one advantage of the GX9 over the GX80/85 is the 12-bit e-shutter. You may (or may not) also find the tilting viewfinder (in addition to the tilting screen) useful - using it can give you a bit less of the "staring straight at you" look, compared to a traditional viewfinder. The GX7 also has the tilting viewfinder.
In the UK at least, the current difference between the GX80/85 and the GX9 is about £150. I'm not sure whether this puts it outside the amount you're willing to spend.
