Fuji X-T100 white balance
Started Oct 29, 2019 | Discussions
HDRI
HDRI Regular Member • Posts: 116
Hi.
This is my first thread on DPR and am still a learner (so kindly forgive if my terminology is bit off the mark)
I recently purchased Fuji X-T100 with 15-45mm as an easy to carry general purpose and landscape camera (esp easy to carry on mountain hikes)
I was just trying some shots and it seems to me its auto white balance selection is bit off, esp in daylight ( I need to change Kelvin value to match the image on the EVF/LCD to real one ). So default colors seem bit wrong. I have Rebel XT along with 70-300 nano usm and 100 f/2. Canon's colors seem better to me (esp the 100 f/2)
Is this known concern (I thought mirrorless are much better at getting white balance right)
Apart from that I quite happy with the body, esp the controls it gives (Canon Rebels for eg. don't allow min shutter speed settings in auto iso, this one does). And am looking forward to later add some better lenses.
One sample shot from the cam
https://www.juzaphoto.com/galleria.php?l=en&t=3358028
Thanks!
 HDRI's gear list:HDRI's gear list
Canon EOS 350D Fujifilm X-T100 Canon EOS M6 II Canon EF 100mm f/2.0 USM Canon EF-M 15-45mm F3.5-6.3 IS STM +2 more
HDRI
OP HDRI Regular Member • Posts: 116
Re: Fuji X-T100 white balance
Any inputs ?
Erik Baumgartner Senior Member • Posts: 6,893
HDRI wrote:
Hi.
Thanks!
If your WB is consistently off in the same direction (too magenta or whatever) you can tweak it to your liking with the WB shift function. I find the auto WB to pretty good in my X-T2 and X-T20, but it does consistently go too magenta in a green forest. I always shoot RAW so I just tweak it in post if necessary.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
beespeckled
beespeckled Senior Member • Posts: 2,249
Erik, Thank you for posting this.
I don't know what happened, but somehow my xt-100 was skewed magenta big time. I don't recall ever messing with my WB w/this camera either.  I've never had a prob w/my other Fuji's. I was thinking it might be the lens combo contributing, but knew I needed to double check my WB settings just to be sure.
 beespeckled's gear list:beespeckled's gear list
Kodak EasyShare P850 Fujifilm FinePix X100 Fujifilm X10 Sony RX1 Sony SLT-A77 +10 more
HDRI
Erik Baumgartner wrote:
HDRI wrote:
Hi.
Thanks!
Thanks.
Yes. That's where I actually chose a higher kelvin value to match what I was seeing. I guess will need to check in every situation to see if its right or needs to be tweaked.
Is this something which can get corrected later by a firmware update ?
HDRI wrote:
Hi.
Thanks!
Thanks.
Maybe, but only if all X-T100s were off. I don’t have one so I can’t help you there. The “as shot” WB value seems ok in Lightroom with the X-T100 RAW files I’ve messed with.
HDRI
That's true
beespeckled
Was it with XC15-45 lens for you too ?
beespeckled
beespeckled
It is the only lens I own for the Xt-100.  when checking the WB settings just now, it was pretty well off to the right towards red/magenta. I now have it set  to the middle of the graph for hopefully a more neutral true color.
beespeckled wrote:
beespeckled
Unless you intentionally move it to bias the WB in a particular direction, it should be in the center by default. People with WB issues often screw up that adjustment unknowingly.
beespeckled
yes, I must have at one point did so for a photo situation, then forgotten. Maybe even thinking I was in the custom Kelvin modes when I was in the auto WB mode. That is the only thing I can think of.
Palden Contributing Member • Posts: 720
That's true
beespeckled
I have the XT100 and 15-45 lens.
I have never had an issue with the WB at all.
My XE1 used to have a green cast, but the XT100 is generally spot on.
As others have suggested check your settings, and also your film/effects modes.
P.
