X-E3 vs X-T30 for small travel rig
Started Oct 27, 2019 | Discussions
mpfef
mpfef New Member • Posts: 23
I am currently looking at downsizing my Nikon gear (D7500) or maybe just adding to my gear by getting something smaller that’s more travel-friendly.
I’m torn between the X-E3 and the X-T30.  I like the RF style of the X-E3 body and the lower price, but how much of a difference does the new sensor/autofocus on the X-T30 make in daily use?
Thanks!
 mpfef's gear list:mpfef's gear list
Canon EOS R10 Canon RF 35mm F1.8 IS STM Macro Canon RF 70-200 F4 L Canon RF-S 18-45mm
SpeedyNeo
SpeedyNeo Senior Member • Posts: 1,055
Re: X-E3 vs X-T30 for small travel rig
I have the X-E3, but if it's your only Fuji, among those 2 I'd recommend the X-T30.
Reasons: better AF, arguably better sensor, built-in flash. Some would also say better overall ergonomics.
Fujifilm X-T3 | Fujifilm X-E3 | XF16mmF1.4 | XF35mmF1.4 | XF18-55mmF2.8-4 | Fujifilm FinePix XP140
 SpeedyNeo's gear list:SpeedyNeo's gear list
Fujifilm XP130 Fujifilm X100V Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +1 more
Doug MacMillan Veteran Member • Posts: 3,695
Full disclosure.  I bought the X-E3 for travel, then the X-E2 for backup.  I have not used the X-T20/X-T30.
As a travel camera, the X-E3 is fine.  AF is snappy.  It is fully capable of your normal travel type photography. I used Leica rangefinders since 1968 and still have my Leica M3.  Shooting with the X-E3 feels a lot like shooting with the Leica, especially the viewfinder placement.
I understand that face detection is very good with the X-T3/X-T30.  It is OK with the X-E3, but can struggle sometimes when the face isn't close.  That is something to seriously consider if you plan to do a lot of people photography.
Both cameras are really great.  Form factor and AF will probably be your decision points.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
io_bg
io_bg Senior Member • Posts: 1,548
Thanks!
I'd get the X-T30. I'm not a fan of the rangefinder-styled bodies and the lack of a tilting screen.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
WhoisDoubleA Regular Member • Posts: 279
They are both dinky compared to your current camera. I have the x-t20 and the AF is same as e3: snappy. The t30 is better. Another poster mentioned eye AF: useless with the x-e3/x-t20 with any sort of busy background or multiple people. Unless you already feel you need it, you don’t need it. Still, if I were buying into a new system I would get the most up-to-date tech so that would be the x-t30. Still, if you want to save some money or spend it on an additional lens, you would not be disappointed in the previous iteration.
 WhoisDoubleA's gear list:WhoisDoubleA's gear list
Fujifilm X-T20
AshleyMC Senior Member • Posts: 2,228
What do you usually shoot when you travel? For such images, do you need the latest technologies in sensor and AF? Or do smaller size and lighter weight take precedence?
Without knowing what you prefer and can tolerate, most people would recommend “the best”. Only you can decide what is most appropriate for your travel photography.
More importantly, have you had the chance to physically handle those two models and determine your own psychological response to each of them?
I use an X-Pro2 and an X-E3. The latter is smaller, but can sometimes feels “too small” to me when my mind intuitively recalls the heft of the X-Pro2 (or, in your case, that of the D7500). Other than that, the size and weight of the X-E3 are truly an advantage when travel. Also, nobody pays attention to me carrying the X-E3.
In brief: X-E3. (Pay attention to the question in bold above.)
jjz2 Veteran Member • Posts: 4,396
Thanks!
I would go with the form factor you prefer and stick with it. Because in another 6 months there will be an xe 4 that trumps the current xt 30 in specs, then an xt 40 that trumps the current xe 4 in specs... and so on and so forth.
The xt30 is 1.5 years newer so yes has some incrementally better specs in some areas.
My advice given your range finder preference, get the xe 3, save money, throw the extra money at lens like the 27 pancake for ultra portability in Fuji world.
When xe 4 comes out, then decide if it’s necessary to upgrade.
Fuji basically has 2 ilc line ups not including the xt 100 or xh1
you have the pro heavier wr rangefinder camera x pro
then the lighter enthusiast oriented non wr xe series
on the other side you have the pro wr dslr style camera xt *
then the lighter enthusiast oriented non wr xt **
on another note, if you plan to keep the d7500 and lenses I might just consider an x100* camera.
But the Fuji water is nice... jump in... I don’t think you’ll lose anything switching from Nikon crop...
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
okmarzo Regular Member • Posts: 200
I have not shot with the X-E3 but I owned a X-T20 and currently shoot with a X-T2 and X-H1. The ergonomics of the X-T20/30 is way too small unless you buy the optional grip. My hands aren't even that large.
I'd highly suggest just getting a X-T2 or if you're willing to spend more money then get the X-T3 for the latest and greatest. The grip of the X-T2/3 feels way better than the compact X-T20/30. The X-T2 is still a fantastic camera.
 okmarzo's gear list:okmarzo's gear list
Fujifilm X100V Fujifilm X-Pro3 Sony a7R IVA
Acrill
Acrill Veteran Member • Posts: 3,166
That kinda says it all.
Autofocus and sensor performance on both cameras is really good, but form factor is something that can help you get the shot.
Photography is about getting the shot, not fighting a camera that doesn't fit your preference. If the X-E3 helps you get the shot, then get it.
Price difference isn't huge, but thats more money saved for another lens or a train ticket.
 Acrill's gear list:Acrill's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
Acrill
Not sure how you can say this when the OP wants to compare the X-T20 with the X-E3. The X-E3 is smaller: http://j.mp/2WLIsu3
He's not asking about comparisons to larger, more expensive cameras.
Gaber
Gaber Veteran Member • Posts: 6,365
You got a lot of good advice already, but here's my 2 cents.
Last year, feeling the same as you, and owning a D7100 and plenty of Nikon glass, I handled an X-E3 at a photo show and fell in love with it. I bought the 18-55, 55-200 and the pancake and expected to use this rig as my travel kit. It was truly liberating to use the X-E3 on 2 trips rather than hauling the D7100, as the kit is only half the size. Pictures are great, as good as Nikon. Now, a year later, I figured that I don't need 2 systems and opted to go only Fuji. I sold everything Nikon and used that money to replace my Nikon lenses with Fuji. One of the posters before me gave you good advice. Find a store and handle the cameras and then go with your gut.
Lotsa luck.
 Gaber's gear list:Gaber's gear list
Nikon Coolpix 4500 Olympus Tough TG-2 Nikon 1 J5 Fujifilm X-E3 Nikon AF Nikkor 50mm f/1.4D +14 more
pixl10 Regular Member • Posts: 308
I like the x-t30. I used to have the X-e3. The flip screen is quite useful. Autofocus is better. Image quality is same. I Like having the on board flash instead of as a separate accessory. Both cameras need added grip with bigger lenses to feel comfortable.
You won't go wrong with either.
 pixl10's gear list:pixl10's gear list
Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R
UConn140point6 Forum Member • Posts: 74
I haven’t had a chance to see either in person but am interested to hear from someone that has.  I have Sony A7R3, which I plan to keep, looking for something really compact to carry around when I can’t have Sony. I had the RX100 V, loved the size but the retracting lens and the EVF had too many moving parts and issues for my liking. I was thinking either the XT30 with the 27 2.8 or the XE4 (when it comes out) with the 27 2.8. Are these combos not super portable?  Any feedback is greatly appreciated.
Thanks,
Mike
Thanks,
Mike
The XE series with 27 2.8 is smaller and lighter than the Fuji X100f... if that tells you anything.
The current X E3 weighs 11.8 oz with battery and card inside. The fuji 27 2.8 is only 2.7 oz...
It will go in most coat and non-slim jacket pockets. Some claim to be able to put them in their pockets, but they must be wearing baggy cargo shorts or something.
So yeah you are going to save some weight. It isn't as portable as RX100 though.
aloli
aloli Regular Member • Posts: 276
I would hold both and test them in the hand if possible. I went from the X-E2 to the X-T10, and then back to the X-E3. For me, the X-E line is far more comfortable in the hand than the X-T10/20/30 line. Of course, you may find the opposite to be true. But this difference would be enough to make me choose the older X-E3 over the newer X-T30 (despite the better AF, sensor and video capabilities).
 aloli's gear list:aloli's gear list
Canon EOS 7D Fujifilm X-T2 Fujifilm X-E3 Nikon AF Nikkor 50mm f/1.8D Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Same here, I think because they are slightly more rectangular combined with the EVF on the side getting out of the way, instead of the more square design with EVF in center. I also use a thumb grip which makes a good bit of difference.
But yeah, somebody else might like some other design.
ReCaptcha Regular Member • Posts: 331
Personally, I don't think the 2 extra megapixels and slightly faster AF make much of a difference.  I think how it feels in hand, or ergonomics in general, would make a bigger difference.  They did for me.
I handled both the X-E3 and the X-T30 in a store and personally did not like the lower location of the X-T30 joystick vs the X-E3's.  There's also a bit more room for your thumb on the back of the X-E3, so perhaps less chances of hitting that Q button (I've never accidentally hit it on my X-E3, but did in the store on the X-T30). I went with the X-E3 because of these little handling niggles, but some do prefer the X-T30.
I do like that the X-T30 has USB-C versus micro-USB (X-E3).  I also like that it has the flash for occasional fill if needed, but the new AF, 2 extra mp, and new charging were not enough to sway me over a cheaper camera that felt better in my hands.  I found my X-E3 for around $425.  At the time it was $475 less than what the X-T30 was running.
I think both are fine cameras...  I echo what others have said.  If you can, hold them before making the jump.
One last thought, if you really like the X-E3 better, but want the current generation performance, then it might be worth it to wait until 2020.  Based what has already been refreshed (X-T3, X-T30, X-Pro3, X-A7) the next left to update would be the X-E and X100 series, and I would imagine most of the goodies from from the current releases will be in the next versions those cameras.  This said, it's hard to argue with the current go rates of the X-E3, and even the new lower price on the X-T30.
Good luck with your choice!
 ReCaptcha's gear list:ReCaptcha's gear list
YI M1 Panasonic GX850 Fujifilm X-E3 Fujifilm X-A5 Fujifilm X-T100 +33 more
Thank you all for the input. Before purchasing anything it makes sense to get to a store to decide for myself which feels better. A slightly used XT30 on FM is going for $600, the 27 2.8 for around $185. The draw for me to the XT30 is the newer features. The XE3 if it had the USB-C and articulating LCD is the most appealing to me, probably makes sense to wait for the refresh.  Thanks again everyone!
holashobby Senior Member • Posts: 1,663
Thanks!
The X-T30 has a pop-up flash and a tilting screen and therefore more flexible, if you are unconvinced about its sensor/processor improvements, x-t20 will be ok.
 holashobby's gear list:holashobby's gear list
Fujifilm X-T4 Panasonic Lumix DC-S5 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm 15-45mm F3.5-5.6 OIS PZ +4 more
Jesper2 New Member • Posts: 2
Thanks!
I've had the X-E3 since 2017,but always use one of my other Fujis (T10 and T2) . The E3's EVF is surprisingly unpleasant (I wear glasses) and I miss the tilting screen. So I'ld choose T20 or T30 anytime. Actually I have just given the E3 away and am reading this thread because I'm looking for a replacement for the E3.
Best, Jesper
