Orion from my bedroom window
Started Oct 27, 2019 | Discussions
OutsideTheMatrix
OutsideTheMatrix Veteran Member • Posts: 9,876
Here is a single frame of Orion from my bedroom window (with the window closed!) 13 sec ISO 400 f/3.5 at 14mm using the kit lens.
No editing of this jpg, aside from cropping and doing an autolevels.
Would stacking a bunch of these in deep sky stacker show more stars or would that just increase the background light pollution (which is very high here- near NYC.)
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
OutsideTheMatrix
OP OutsideTheMatrix Veteran Member • Posts: 9,876
Re: Update (plate solved!)
Astrobin plate solved it for me to label all the stars they can detect (click on it to get full res):
https://www.astrobin.com/kje32b/
I'm still wondering whether stacking a bunch of these with DSS would bring out even fainter stars or would it increase the light pollution?
OllieN Regular Member • Posts: 445
Stacking doesn't increase the light pollution.  It does increase the signal to noise by average out the random noise created by your camera.
To see more stars you need to subtract the light pollution from your image and then stretch the signals from those stars to make them brighter.
Having less noise allows you to stretch further.
Never tried it from such light polluted skies but other forum members have previously got some stunning results from city areas.
Stacking from RAW rather than jpg will be important
Hope that's somewhat helpful
 OllieN's gear list:OllieN's gear list
Nikon D5500 Sigma 105mm F2.8 EX DG OS HSM Tokina 11-20mm F2.8 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-P 70-300mm F4.5-6.3G VR +1 more
OutsideTheMatrix
Thanks, I will stack them then, I took about 20 images using these same settings!
Here is the original unedited image so you can get some idea of how bad the light pollution is here.
Should I stack using the crop (with autolevels applied) or should I stack using the original unedited subframes and edit later?
DavidWright2010 Veteran Member • Posts: 3,745
I don't know if it matters; I would stack unedited frames.
The important thing is to export the images from your raw converter as 16 bit tiffs, then process further, starting with stacking in DSS.
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
swimswithtrout Veteran Member • Posts: 4,232
David
Do not convert to TIF before stacking as that destroys the linearity of your stack.  DSS has it's own built in RAW converter, there is no need to convert to a larger file TIF before stacking.
