Software to add Lens EXIF info
Started Oct 26, 2019 | Discussions
ruhell Regular Member • Posts: 138
Hi
I have quite a few old adapted lenses that I have used with my EOS 6D, and I've been using ExifTool GUI to add lens info (Lens make/name, focal lenght, f stop, serial#) into the rawfiles. This summer I upgraded to an EOS R and unfortunately ExifTool GUI doesn't recognize Canon's new CR3 files and will not handle them. ExifTool GUI is also abandoned and hasn't been updated for many years so I don't think there will be a fix for that. I don't feel like doing this via Exiftools command lines either.
Also I do not use any Adobe software, so any plugins for Lightroom (like Lenstagger) will not make the cut for me.
Then the real question, do any of You know of any other software that can do this? Hopefully with a possibility of batch prosessing multiple photos at once. Any recomendations?
And while at it, has anyone seen any or heard any rumours of upgraded Dandelion chips, or their like, that will fit the RF mount?
Regards Rune
Canon EOS 6D Canon EOS R
Travis Butler
Travis Butler Senior Member • Posts: 1,412
Re: Software to add Lens EXIF info
On the Mac side, GraphicConverter allows editing a long list of EXIF tags; they include the Lens Name and Focal Length, which are the most important ones for me.
With an image browser window open, just select a batch of images, right-click on one, choose EXIF, then Edit complete EXIF.
Flickr at https://www.flickr.com/photos/the_prof67/ Warning: Heavy Learning in progress.
 Travis Butler's gear list:Travis Butler's gear list
Fujifilm X20 Nikon Coolpix A Pentax Q Pentax K-50 Panasonic Lumix DMC-GM5 +18 more
ddharriman Forum Member • Posts: 63
Hello
Check is this can help with your problema: https://www.jazzycamel.photography/NameThatLens
Best regards,
OP ruhell Regular Member • Posts: 138
Unfortunately/luckily Windows, but thank You
Thank You, will check it out
