Storage for storage and travel
Started Oct 25, 2019 | Discussions
Dann-Oh Contributing Member • Posts: 894
Hey all,
I am starting to put together a camera kit.  I currently have the below kit. I am starting to understand that this is quickly going to be an unwieldy (to organize) and expensive hobby, I'm okay with it.  My main question is what is the best way to store/organize my small but growing kit for easy travel.
Camera: Sony RX100Va
Housing: Fantasea FRX100VA VAC
Light: Kraken Hydra 1000 WSR+ (not a strobe but a handheld light for now)
Wet Lens: Inon UCL-165M67
Stuff: 2x extra batteries for camera and 1x extra for light
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
daveco2
daveco2 Contributing Member • Posts: 953
Re: Storage for storage and travel
Will you be packing all of your own SCUBA gear?
Will you want to put your expensive and/or difficult to replace gear (camera, housing, regulator, prescription mask, laptop and external storage, for example) in a carry-on?
Where will you be traveling, and do small connecting airlines have baggage restrictions?
 daveco2's gear list:daveco2's gear list
Sony RX100 Sony a7R II Sony a7R III
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
It depends on how much gear you end up with.  I have to split my camera gear into a rolling backpack + a waist bag + some bits in a suitcase.
With what you have there I'd just fit it in my waist bag (Think Tank Speed Racer).  If you get more gear and can't fit it into a waist bag anymore, I'd go for a backpack or roller bag.
You tend to want to keep all that gear together in a single bag if you can.   WIth a waist bag you have some advantages:
1. Puts the weight on your hips instead of shoulder and back
2. Limits the weight you carry to what fits in a waist bag
3. Keeps both hands free
4. Can be rotated to the front to work out of standing up, and also allows you to sit with the bag.
Alternatively, a roller bag for bigger, heavier gear.   Again, get the weight off your back.
Any gear you take on a plane needs to be able to fit under a seat in a pinch.  Think Tank makes a number of bags that meet that criteria.
Splitting up your gear is a good way to leave some of it at home by mistake.  I use a checklist when I go diving because there are so many different parts and bits to bring along.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
OP Dann-Oh Contributing Member • Posts: 894
These are good things to think about.   Thanks.
I think right now I will be doing relatively local (Southern California, USA) for the near future.  I have a lot of diving locations to explore here, as well as a lot of skills to learn as I am still young in my diving career.
Since I have a small bit of gear and I don't plan to get much more (maybe a strobe and tray in the near future) I decided to repurpose my Apachee 4800 (knock off pelican case).  As you can see I have plenty of room to expand a little bit.  The camera will fit in the pocket in the top left corner.
I am currently okay with the briefcase-style case for now.
kelpdiver Veteran Member • Posts: 5,564
the smaller think tanks are quite versatile - carry laptops, tablets, and various other bits.  Not too heavy, and not nearly so obvious as the pelicans which empty can exceed the weight allowance, and scream "valuable stuff inside."
The Airport Advantage is a bit smaller than the largest US permissible carryons - 7.3" D rather than 8" of the International....some international airlines have the official limit at 7.8", and some do make you put it in the sample tray at checkin.    Since you're using compact cameras, you shouldn't need the bigger size anyway.
I'm trying to work out the right way to store stuff at home, to then load into the luggage.   The checklist isn't the same, taking 1-3 of up to 5 system choices with a number of shared parts.   My dilemma is finding some parts - a problem that started with a variety of bags of goodies, some purchased just before trips, and then a home move that really killed any sense of order.
I think I may go full pedantic and label each ultralight arm piece and joint with a unique number and do checkouts like a library.  Maybe a stack of bins.
daveco2
What bags do you check in?  Do you have a problem with carry-on excess weight?  Do you have a problem with excess baggage fees?
Do you carry a second backup camera and/or housing?
Do you carry a laptop?
I just got back from a long trip with Philippine Airlines, economy class: a 44 lb duffle filled with some dive gear and two housings (checked), a 35 lb roller bag filled with lenses and strobes (checked), and a carry-on backpack filled with laptop and two camera bodies.  There was no room for wetsuit and BCD, so I rented those at the destination.
In economy class, for flights to Manila on a large plane, PAL allows you to check two, 50 lb bags and to carry on 15 lbs.  For their smaller domestic flights (important if you're going on to a smaller island), they allow 15 lbs for carry-on and one checked 44 lb bag.  For their domestic flights, you can get an allowance for a second 44 lb bag for $15 if you purchase it before arriving at the airport.  At the airport, that charge is $150.
On my next trip to the Philippines, I plan to check two large duffles, adding a wetsuit and BCD.
Any suggestions?
PHXAZCRAIG
We all have problems with excess baggage fees...
I am NOT a light traveler. When my wife was alive, we did a lot (LOTS!) of travel, and we typically checked 4 suitcases (50 pounds each), and brought two carryons with, plus a 'personal item'.
In our defense, 75 pounds of that was dive gear.
I usually get one bag checked (per person) free, if I use an airline for which I have the airline's credit card. I then pay for a second bag.
Since my wife died, I've been traveling alone more, and if I am diving I have a lot of gear to pack. Besides my dive gear, I have my dive camera gear, which mostly does not go in checked luggage.
Yes, I usually do. That second camera is an RX100 II with Nauticam housing. It uses the same strobes as the main rig, so mostly I just bring the housing with camera inside it. I put that housing into the middle of my waist bag. The other two internal compartments hold my 105vr macro and 16-35vr lenses that I use in the main rig. Very occasionally I add a small prime (since that is the only thing left that could fit). Maybe a 50F1.4g or 85f1.4g.
For work, yes, because I'm an IT guy. But I rarely travel for work. For vacation, no, unless I'm on a dive trip. Unlike my late wife, I have no issues leaving the internet behind for a couple of weeks. If I am on a dive trip, I want to review my shots nightly and correct any issues before the next day. I'm still on a learning curve for underwater photography.
In my case I would have all my dive gear in a large suitcase. Or almost all. I simply cannot fit my dive gear, my camera gear AND clothes into a single 50 pound suitcase, so now I check a small bag as well. I'll split stuff as needed between the two checked bags.
In those checked bags I have my dive gear (except my dive computer stays in carryon), a 90mm extension tube for the dome port, and the 105mm macro port. Inside the 90mm extension I cram all the clamps for my strobe arms and focus light.
I have lots of neoprene (wetsuit, hood, gloves)  to pad the few camera bits in there, but I also carry a AO 36 quart collapsible cooler to carry the camera rig on and off boats, and to act as a rinse tank in a shower as needed.  The cooler provides a lot of additional padding, and I pack my laptop inside of it.   This suitcase is invariably opened by TSA to check the laptop.  If I travel without the laptop, TSA usually leaves this bag alone.
In the small suitcase, I put virtually all the clothes I need, toiletries, etc.
I use a roller bag instead of a backpack for my dive gear carryon.  Basically I had the bag and needed to find a use for it.  It was originally purchased to replace my backpack, and I thought there were backpack straps hidden in there.  But it had no backpack straps. (I wanted the option to backpack it, especially for those airports that weight rolling carryons. The bag weighs at least 30 pounds packed.
Ouch!  Better set that up ahead of time.
Any suggestions?
Not much, other than some common sense stuff:
1. always bring a scale to weight luggage and stay within limits.  I use a simply analog one from Walmart.
2. be prepared to repack things into pockets if getting weighed at the airport
3. if you have a collapsible dive duffel bag, it can be pressed into use as an additional carryon at the end of a trip if you have picked up souvenirs and the like.  My late wife used to pack it full of dirty clothes at the end of a trip.
4. If you have a backpack, and a strong back, you can wear a waist bag at the same time as a backpack by rotating the waist bag to the front.   This is how I typically went through airports before dive trips (before the rolling bag and huge housings).   The problem here is that you cannot use the waist strap on the backpack at the same time as the waist bag, so you get a lot of weight on your shoulders.  But I only do this going through airports, so it's not usually on my back more than an hour at a time.   The benefit is that both hands are completely free.
Ideally I would have a roller bag with backpack straps to be used when it is advantageous to have the backpack instead of the roller.  Or maybe I should get a collapsible luggage cart and just use the backpack instead of the roller.  Thing is, I don't want to redo the insides of my backpack to go from dive trip to non-dive trip, so I keep using my roller.
5. Bring along a luggage strap with a plan on how to use it.   When I went to Roatan the first time alone and had two checked bags, I ran into a problem at the airports.  I now had THREE rolling bags, and only two arms.   I bought a luggage strap at Walmart and set it up to hold my camera roller bag on top of the smaller suitcase.  I only have to get the bags between cars and airport counters, so it's not too bad.
With my system, I have minimal camera gear in checked bags.  The housing (with camera inside) stays in carryon.  The backup housing (RX100) also.   The 230mm dome port definitely goes in carryon.    The lenses go carryon.   The only glass part that goes in checked luggage is the 105 macro port - just no way to fit it anywhere else.   I bet if I had a backpack instead of roller bag I COULD fit it, and probably the 90mm extension as well.   But I would then have about a 40 pound backpack, plus another 15 pounds in my waist bag.
6. Don't be shy to pay a porter to handle your suitcases.  As we get older, this is more and more an attractive option.
I always bring my own dive gear, including wetsuit.   They don't weigh all that much, and they are good padding.  I want to make sure I get something that actually fits me as I am not the average male size.
I'd actually love to bring both my D810 and D850 rigs along, and it wouldn't be a lot of additional stuff, though a D810 inside a Nauticam housing is certainly not that small.  But I would have to check it, or I need a companion traveler to carry it for me.    Would be nice to have one set up with the dome port (D810) and the other set up for macro (D850).  Bring them both on the boat...   Only one would have strobes though.
www.cjcphoto.net
the carryon weight limit is generally not applied to camera gear.  They acknowledge it isn't safe as checkin, and well past their coverage limits.   So if you have a think tank with a camera and lenses obvious in view, along with strobes and such, the counter staff should be fine.   Only rarely have I encountered them weighing it, though I have less experience with the tiny island hoppers.
I stow my housing itself in my laptop bag, as it's too big for my think tank.   I don't have the largest carry on model, as international airlines don't all allow for 9x22, and empty those things weigh 10+ lbs.
