Leica m240 with Voightlander 25mm f4 street
Started Oct 24, 2019 | Discussions
Corot2 Senior Member • Posts: 1,704
Hi
Looking for a good low cost lens for street photography
Anyone use the 25mm f4 voightlander on their digital leica for street
I have a summarit as my walk around but when I need to zone focus wanted something with a wide range and wanted to see others experiences
Thanks very much
Lou
 Corot2's gear list:Corot2's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-E2S +11 more
jeffharris
jeffharris Forum Pro • Posts: 11,635
Re: Leica m240 with Voightlander 25mm f4 street
I have a Voigtländer Color-Skopar 21mm f4 (using with M4/3 cameras) that's just great.
It may be a bit wide, since you're considering a 25mm. But it's definitely worth a look.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
OP Corot2 Senior Member • Posts: 1,704
Thank you
Archiver Veteran Member • Posts: 3,792
The Voigtlander 25/4P works wonderfully on film cameras, but has issues with full frame Leica digital, giving a fairly strong red edge on the left side of the frame. Every time I try to convince myself that I can live with it, I give it a go and the red edge is just too much for me to process out in post. Unless the M240 has a different response compared with the M9, I don't think the 25/4P is worth it unless you only shoot black and white with it. For a 25mm lens, you're much better off with the Zeiss 25mm f2.8 Biogon.
Archiver - Loving Every Image Captured Always
http://www.flickr.com/photos/archiver/
Sjak
Sjak Veteran Member • Posts: 7,622
Do you know if this red edge also affects the total luminosity in the affected area? Or does it only shift the colour balance in that area?
(I ask, because I have a CCD Monochrom, on which the colour cast itself would obviously not be visible )
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR III Ricoh GR IIIx Pentax K100D Pentax K10D +3 more
Strangefinder
Strangefinder Senior Member • Posts: 1,355
lou Capeloto wrote:
Hi
Thanks very much
Lou
I understand that Voigtlaender have just released digital-friendly re-designs of the 21mmF4 jeffharris was referring to, and the 35mmF2.5 pancake.  They're now half a stop faster (F/3.5 and F/2), and perhaps bigger, but the performance will be significantly better on the typ 240.
If that doesn't bother you, though, then the other logical consideration is the ZM25mmF2.8, which is compromised on digital, yet broke records on film.  Or an old 24mm Leitz.
"Hokey religions and rangefinder cameras are no match for a good blaster at your side, kid."
Tomm111 Senior Member • Posts: 2,272
Another lens to consider is the 25 f3.5 Canon, works well on my CL (except Infrared on the CL) and M8 (where Infrared is fine). I used it with full frame film cameras and it has good FF coverage. A total pancake lens. Have used this lens and a Nikkor 25 for street photography in tight places, subway station and alike. The interesting set up was the Nikkor on a IIIC, ultimate tiny camera.
 Tomm111's gear list:Tomm111's gear list
Leica M8 Nikon D300 Leica CL Tokina AT-X Pro 11-16mm f/2.8 DX Leica Summicron-M 50mm f/2 +21 more
From what I see, it does result in a slight vignetting effect, only on one side.
Sjak
Thank you for checking! Probably I'll pass on this lens... even if it's not expensive, I'm not sure if it's a "character" i'd like (normal corner vignetting is no issue for me)
Just to let you know: I did some more tests, and found three things.
1. the red edge colour shift on the left can be mostly removed with the Gradient tool in Lightroom. You lay a gradient over that part of the image and desaturate red/magenta until it is gone. This is not a perfect solution, especially if there is red/magenta in that part of the image, but it does work for most situations.
2. There is not as much of a darkening vignette effect as I thought, and this occurs more at higher ISOs. There are times when the red edge is minimal or not visible at all. I haven't been able to figure out what the difference is yet, but it's not as bad as I thought.
3. Setting the M9 to the 24mm f2.8 lens correction takes out a lot of the red edge.
It seems that the earlier shooting I did with this lens were at high ISO's like 1600. ISO 400 hardly shows any red edge at all, and what is there can be removed with Lightroom's gradient tool. So it could work for street in good light, and in slightly lower light if you shoot in black and white and/or don't shoot with a red or magenta background. I like this lens a lot for film, so we'll see what happens if I take these new things into consideration.
Sjak
Thank you! Maybe I'll give it a try... It's by far the most affordable wider than 28 lens available. I'm not totally sure if it works for me, to have a lens that is wider than the viewfinder FOV, so don't want to put a large initial investment into it.
If you're okay with secondhand goods and the resale thereof, you could quite easily get a nice condition copy secondhand, and sell it for pretty much the same money if you don't like it.
