There will be a brief outage for database maintenance in approximately 2 hour(s) 33 minutes
? Variable ND filters + Polarizer ?
Started 2 months ago | Questions
RUcrAZ
RUcrAZ Veteran Member • Posts: 6,057
I assume that variable ND (neutral density) filters are made by using two polarizing filters, rotating against each other. (Yes, no?) If yes, does this mean that one cannot use a circular polarizing filter, in combination with a variable ND filter? Bottom line question: can both be used simultaneously? Thank you.
Horoscope Fish
Horoscope Fish Contributing Member • Posts: 913
Re: ? Variable ND filters + Polarizer ?
No. Neutral Density does not equate to polarization.
Yes, they can be used together, Breakthrough Photography even offers a CPL/ND combo filter.
https://www.the-digital-picture.com/Reviews/Breakthrough-Photography-X4-Dark-CPL-Filter.aspx
 Horoscope Fish's gear list:Horoscope Fish's gear list
Nikon D850 Sigma 50mm F1.4 DG HSM | A Tamron SP 70-200 F2.8 G2 Sigma 135mm F1.8 Art Tamron SP 24-70mm F2.8 G2
RUcrAZ
OP RUcrAZ Veteran Member • Posts: 6,057
I am not sure that my question (about "variable" ND filters) was answered. In the past, I have successfully used ND filters in combination with plain ND filters.
ZodiacPhoto
ZodiacPhoto Senior Member • Posts: 2,767
Yes, variable NDs are made of two polarizers. Adding a third polarizer will lead to unpredictable and undesirable results.
 ZodiacPhoto's gear list:ZodiacPhoto's gear list
Sony RX100 III Sony RX100 VI Olympus OM-D E-M10 Sony a7R II
FrancoD Forum Pro • Posts: 11,204
Your first comment is correct.
From Hoya :
The variable neutral density effect is created by employing two polarizing filters within one filter design. That is 2 pieces of glass and 2 layers of polarizing film creating 8 surfaces within the filter. As light passes through a low-quality filter it will bounce around those 8 layers within the filter degrading sharpness, contrast, and clarity. So using low quality glass, polarizing films, and little to no multi-coatings, like most low-cost competitors, will wreak havoc on your pictures.
The Solas NDX uses the highest quality optical glass, super-thin optical grade polarizing films, and multiple layers of Hoya’s patented multi-coatings on each of the 4 sides of glass. The result is a sharp, glare-free filter that produces superior quality images you can trust.
http://solasndx.hoyafilterusa.com/
BTW, there is at least one type that clims to offer variable ND and full PL at the same time but it comes in only two sizes :
https://www.genustech.tv/Polarizer-ND-Variable-Filter-s/177.htm
from the depolarisation comments I read on the first Hoya link I posted, my assumption is that using VND and PL on top is not a good idea, but I don't have direct experience with this.
ND and Variable ND filters are not made the same way.
24Peter
24Peter Veteran Member • Posts: 3,553
I believe Zodiac is correct.
 24Peter's gear list:24Peter's gear list
Nikon D750 Nikon D850
DeathArrow Senior Member • Posts: 2,313
I did use a CPL filter on top of a variable ND filter. Not that I needed polarization very much but the CPL darkened the exposure a bit and I needed a longer exposure time.
 DeathArrow's gear list:DeathArrow's gear list
Nikon D750 Nikon AF Nikkor 50mm f/1.4D Tamron SP AF 90mm F/2.8 Di Macro Sigma 85mm F1.4 EX DG HSM Tamron SP 24-70mm F2.8 Di VC USD +3 more
Mark B. Forum Pro • Posts: 26,259
Actually the OP is correct - variable ND filters are essentially 2 CP filters stacked.
BBbuilder467 Veteran Member • Posts: 3,816
I have stacked a variable ND over a CPL and it worked, but it was such a pain to adjust and control that  I prefer using the standard ND for stacking.
