RF 15-35 chromatic aberration?
Started Oct 22, 2019 | Discussions
vel New Member • Posts: 17
Hi,
Few days ago got 15-35 for EOS R.
Fantastic lens., but seems lens has excessive chromatic aberrations. Not sure if it's my copy or just by design.
15 mm 1/500 sec at f/5.0, ISO 800
Zoom
Dave Lasker Regular Member • Posts: 345
Re: RF 15-35 chromatic aberration?
I don't have that lens, but a good test would be to see how well the lens profile in DPP, Photoshop/Lightroom, or SOOC jpeg minimizes the the CA. If you sill have a lot of CA remaining after applying the lens profile, you might want to contact Canon support.
 Dave Lasker's gear list:Dave Lasker's gear list
Canon EOS RP Canon RF 24-105mm F4L IS USM Canon RF 24-240mm F4-6.3 Apple iPhone XS
lighthunter80
lighthunter80 Contributing Member • Posts: 990
vel wrote:
Hi,
Zoom
This looks like the worst scenario possible and most lenses would exhibit some fringing here. IMO, this looks ok.
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
shawnphoto Senior Member • Posts: 1,307
vel wrote:
Hi,
I don't have this lens but that type of bluing is normal. I do see some CA elsewhere in the image but it appears to be in the bokeh or to the edges which is normal.
How does it perform at 35mm? According to The Digital Picture review the CA of this lens is well controlled but is most prominent at 15mm.
Obviously a zoom lens is going to have more CA than a prime lens typically.
Here is an image I took with my RF 28-70 L at f/5. You can see that at the plane of focus in the center it's really good but at the edges and in the bokeh there is some CA visible in this high contrast situation.
All in all I would say your lens is normal.
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
OP vel New Member • Posts: 17
Lightroom does not have yet profile for that lens. I tried to manually remove CA in Lightroom, but it had marginal effect I expected this lens would have less aberrations without digital correction.
 vel's gear list:vel's gear list
Canon EOS R
Did not test with other focal length yet. I have same kind of CA with 24-105,, but not that prominent like 15-35 at 15.
Canon EOS R
With CA like this you have to do it manually.
I tried, it creates some artifacts if pushed to max. Sure some post process will help, but to defringe blue CA on bluish background is not easy.
Canon EOS R
Claude Ganter Regular Member • Posts: 109
This is 15-35mm@15mm f/5.0 as well, the top-left corner. About 1mm square area at 400%. Left with ACR chromatic correction. Right without. No purple was removed.
Claude
Guess it is what it is. May be it will be addressed in the profile. Also have to be more cautious with light at 15-17 mm. Otherwise this is outstanding lens. Few pictures.
15 mm 1/60 sec at f/5.0 , ISO 100
15 mm 1/80 sec at f/2.8 , ISO 1,000
17 mm 1/640 sec at f/16 , ISO 1250
17 mm 1/60 sec at f/16 , ISO 125
15 mm 1/640 sec at f/3.5, ISO 1,000
21 mm 1/1250 sec at f/5.0 , ISO 1,000
Canon EOS R
Did you try in DPP?
Rawpaul
Rawpaul Senior Member • Posts: 2,567
Nice images , nothing to complain there IMO
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
No I did not try DPP, but I tried manual in ACR and Lightroom. Same result. I cannot remove bluish fringing on blue background. It creates blotches all over if pushed too much. It seems that on wide end better to step down aperture to keep it in focus for backlit scenarios. I don't see excessive CA at 17mm and longer.  I had Sigma 8-16 on 7D Mark II. Never had such problem, so that was kind of unexpected behavior for 15-35. I just not sure if should I try another lens.
Manual correction in LR .
Canon EOS R
Unfortunately the image is overexposed. When shooting these types of scenes I recommend using the highlight tone priority setting. I just leave it on all the time.
If the image was not overexposed you could select the sky only using a blend layer in Photoshop like this:
This is one shot from HDR triplet. Processed image is below. I shot in RAW, I guess  highlight priority does not affect image. I use FV mode, as default reset all and adjust T/A/ISO as needed while focusing. For exposure compensation I use lens ring. I found convenient to program right side of bar show/hide histogram and adjust compensation by left hand.
I was thinking about fixing it, but my point is not how to fix bad image, but what to do to avoid bad images. Including changing the lens, but I think in some conditions CA is unavoidable especially for ultra wide.   I can fix it in Photoshop, but it takes to much time. Anyway thanks for advice, from three images mask should be OK.
Canon EOS R
Just for fun, try the lens profile in DPP and see how well it reduces CA compared to your manual approach. It is works well, then you should be in good shape once Adobe releases a profile for your lens.
I am always amazed at how well Adobe's lens profiles work once they are finally released. For example: the RF 24-240, which is totally useless without a good lens profile.
I retested today in similar conditions and came to conclusion that CA is negligible and will be handled by profile or manual. When shooting in this conditions background should be in focus. Blur will increase CA. Today I had only nice purple CA that I manually removed Anyway I will try DPP later. Thanks.
Canon EOS R
I have checked the highlight tone priority, it affects the image in RAW as well.
I tried profile in DPP. Much better then my manual result. I moved Digital lens optimizer to 100%. Thanks a lot. Hope to see it LR soon.
Canon EOS R
That's a bit questionable. https://www.dpmag.com/how-to/tip-of-the-week/using-highlight-tone-priority/   I try not to overexpose. But thanks for correcting me. I should try it on R.
Canon EOS R
